500 user(s) are online (157 user(s) are browsing Forums)
Kj4life Re: A Question About Ignition Modules
Birmingham Alabama
3 Posts
I have a 86 4+3 and sprayed engine the other day and since have to cover and uncover air flow to start please help
Posted on: 2016/3/6 21:56
Kj4life Kj
Birmingham Alabama
3 Posts
86 will run bit when I turn off want start back without covering air flow
Posted on: 2016/3/6 22:01
Matatk Re: Kj
22996 Posts
Sorry, I don't understand the question completely.
You're saying your 86 won't restart after it has run? What is "covering air flow"?
Posted on: 2016/3/7 2:14
Matatk Re: Kj
22996 Posts
I also merged your two threads since I noticed you also posted in an unrelated thread. If you can be more specific, we will do our best to help.
Posted on: 2016/3/7 2:16
Kj4life Re: Kj
Birmingham Alabama
3 Posts
I pressure washed it on Friday and Saturday started it and it was idling high at 18 so ran it for a while and turned it off and wouldn't start back had to spray a mist of gas in the breather please help
Posted on: 2016/3/7 12:50
Schrade Re: A Question About Ignition Modules
Might have forced water into intake.
Got a fuel pressure gauge? And pull distributor cap - make sure no water inside.
Hard re-start when hot can be low fuel pressure - need to know fuel pressure.
Posted on: 2016/3/7 15:01
Matatk Re: Kj
22996 Posts
Unfortunately pressure washing the engine is usually a bad idea. Oftentimes water will find its way into the electrical connectors and various places. It is possible you got water under the cap. You can pull the cap and make sure that is not what underneath. Sometimes the only thing you can do is let everything dry out. Running the motor will help speed that up.
If you continue to have starting problems we will diagnose that problem.
Posted on: 2016/3/7 21:44
