584 user(s) are online (301 user(s) are browsing Forums)
« 1 2 (3)
shamdave Re: Fiat headlights
14 Posts
Any one got a clue on how to wire these damn things
Posted on: 2011/6/2 23:11
14 Posts
need to know the wiring diagram for the 20vt head lights One plug in has
3 wires total
2 black
1 white with a black stripe
the other has
4 wires total
1 green
1 gray with black stripe
1 green black stripe
1 gray
Please Help I need to know
what is Positive and what is Ground?
What controls what?
HELP!
Posted on: 2011/6/3 0:29
Matatk Re: Fiat headlights
22996 Posts
Are those the wires on the Fiat lights you are installing?
Stock Corvette wires should be:
tan - low beam power
lt green - high beam power
black - ground
Posted on: 2011/6/3 1:25
22996 Posts
I'm trying to find some info on the wiring diagrams, but it's a bit tough. Heck, took me 20 minutes to find out a "dip" headlight is basically the low beam...but headlights appear to be wired differently in Europe for that feature. And they are lh/rh drive specific. Interesting.
http://en.wikipedia.org/wiki/Headlamp
http://en.wikipedia.org/wiki/Automotive_lighting#Dim-Dip_Lamps
Posted on: 2011/6/3 1:48
14 Posts
black - ground
yup he sent me the wiring harness
so in short any thing with a black stripe is ground?
Posted on: 2011/6/3 1:52
22996 Posts
No, not anything with a black stripe is a ground.
I think you'll have difficulty using the stock fiat wiring harness. That is set up for a main high beam/driving light in the center and the outside light is a dip light with a motor. They both appear to be controlled by separate circuits with relays and of course a switch.
Also, those headlights appear to use an "h1" bulb as opposed to an h4 like the vette would use.
If it were me, I'd ditch the side lights, and just use the center section for the main beam. From what I've read, the h1 wiring should fit the h4 light bulb, too, but you'll have to verify this.
This is all theoretical at this point. I know zero about Fiat/European wiring and I'm not too good if I can't see what I'm working on.
Posted on: 2011/6/3 2:09
14 Posts
Posted on: 2011/6/9 13:21
383tpimachine Re: Fiat headlights
Corpus Christi
976 Posts
Killer.
I really need to start working on mine again...
As for wiring my dad is an electrician of sorts and said he would take care of it for me
Posted on: 2011/6/9 14:36
1970 El Camino-Awaiting LSX
flyboy Re: Fiat headlights
Looks great.
Posted on: 2011/6/9 15:20
14 Posts
Thank you all I think it turned out OK given Im a no talent hack
Posted on: 2011/6/9 17:26
bogus Re: Fiat headlights
I love the look!
Posted on: 2011/6/9 21:11
14 Posts
Posted on: 2011/7/19 19:06
22996 Posts
Looks great!
Can you share the information you found out about wiring the headlights in?
Posted on: 2011/7/19 21:57
IMPRESSIVE! That is a ton of work and looks absolutely fresh, original and factory.
Posted on: 2011/7/19 22:24
14 Posts
Matatk wrote:
Looks great!
I actually gave up and took it to Spade Kreations.
However I am sure Nick @ spade would be more than happy to walk you through it. He is a awesome guy Tell him it was Dave's 85 with the Fiat lights I am sure he wont forget it any time soon.
Spade Kreations
spadekreations.com
(513) 742-9380
Posted on: 2011/7/21 22:36
14 Posts
Thanks I fell in love with her all over again
22996 Posts
shamdave wrote:
Matatk wrote:
Looks great!
Spade Kreations
spadekreations.com
(513) 742-9380
I just thought it would be nice for folks in the future who are referencing this thread.
Posted on: 2011/7/21 23:11
Corpus Christi
976 Posts
Congrats.looks good. Can you get some night pics with the low and high beams on against a wall?
I really need to get on the ball. Damn classic cars wanting attention
Posted on: 2011/7/22 5:05
Trae1976 Re: Fiat headlights
Johnson City, TN
832 Posts
Nicely done!
Posted on: 2011/7/22 11:40
Corpus Christi
976 Posts
Bringing this back from the dead.
Headlights are being shipped back to me.Going to finish the swap and throw it on the new setup.
Posted on: 2016/4/23 0:49
cool!!!
Posted on: 2016/4/23 4:31
22996 Posts
Is that a company making them or doing a retrofit or what? How will you address the wiring?
Posted on: 2016/4/23 14:02
Corpus Christi
976 Posts
Company that retrofits them. These will have a plug and play harness for the stock C4 wiring. Just need to figure out where to mount the ballasts.
The stock plugs are long gone.
Posted on: 2016/4/23 23:26
what about installation?
Posted on: 2016/4/24 2:11
Corpus Christi
976 Posts
Hood is nearly done. Once they get back I will finish the mounting.
Posted on: 2016/4/25 1:02
« 1 2 (3)
