527 user(s) are online (187 user(s) are browsing Forums)
Schrade In-depth Opti article...
Excellent write-up on Opti system:
http://www.superchevy.com/how-to/0310 ... -understanding-modifying/
Linked to F/B C4 page; not many there will get much from it, as opposed to here...
Bill, Andy, Matt, maybe integrate into one of tech stickies, without my name - need no 'credit', then delete this one???
Posted on: 2016/7/20 16:22
BillH Re: In-depth Opti article...
Interesting article, however:
OptiSpark Maintainence:
Buy your 92 or later C4.
Buy 2 new Opti's, keep one in your shop and one in the car.
And, the article stated that the 92-94 "tended to retain moisture", amusing.
GM designed the Opti with a cheap paper gasket for the cap and then put 2 coolant bleeder screws right above the water pump.
Yes, some will preform for many miles and some won't.
It's the "some won't" that's the problem.
Posted on: 2016/7/20 23:08
BrianCunningham Re: In-depth Opti article...
All my '95 needed was a cap & rotor @ 120k
I don't exactly baby it either.
Posted on: 2016/7/21 14:58
bogus Re: In-depth Opti article...
the larger bearing in the gen 2 opti helped a lot with lifespan.
The Mitsubishi sourced optical sensor is killer durable... 300k or more. A friend worked at a Dodge dealer and saw a lot of them come through in Mitsu engines, and with tons of miles on them, still going strong.
A simple fix for the Gen 1 is to pickle the cap to opti chassis with copper RTV, then, using some line and fittings, a coolant drain bypass will work wonders.
Posted on: 2016/7/21 22:06
Schrade Re: In-depth Opti article...
Probably why my '94 was datastreaming perfect signal @ 89k @ rebuild, with 15 years on it...
Posted on: 2016/7/22 13:56
