306 user(s) are online (276 user(s) are browsing Forums)
KellyBigdaddy vats
buna
7 Posts
I need to put a new ingniton key switch in this car the other day i could not get the dam thing to trun off with out pushing in and truning it forward would it unlock and trun off never seen a GM car do that would like to take out the vats and have a new switch what is needed to do this and who sells the parts
Posted on: 2017/6/4 22:33
bogus Re: vats
what year?
The easy way, if pre-1995 (IIRC), is to measure the resistance of the chip and match it with resistors, then, plug them into the little VATS wire.
Posted on: 2017/6/4 23:12
Matatk Re: vats
Welcome to the forum.
There are VATS bypass kits that you can purchase (premade resistor with wire/connector) that you connect in line with the factory wiring in the steering column. This mimics the key pellet resistance.
That being said, your issue does not sound VATS related.
First thing I would do is clean the ignition cylinder and lubricate with some graphite. See if that helps.
What year and transmission do you have?
Posted on: 2017/6/5 0:19
KellyBigdaddy Re: vats
buna
7 Posts
its a 89 the switch hangs up it will crank but then its like hell to trun off and it will not switch to acc it is a auto
Posted on: 2017/6/5 0:30
joeld Re: vats
What Matt said. Also possibly the inter-lock cable that connects from the shift assembly under console up to the steering col. There's a solenoid at the shifter that acts up sometimes.
Posted on: 2017/6/5 2:13
hcbph Re: vats
269 Posts
Have the 'dongle' on mine. Easy to do - unhook the wires from the steering column at the connector and plug this into the wires going behind the DIC. Just need to have the right resistor value based on what's on your key.
Agree it sounds like something in the lock cylinder, not VATs related. A good locksmith or Garage should be able to change out the cylinder if that's the issue.
Posted on: 2017/6/5 16:15
buna
7 Posts
so I could keep my oem key and just change the lock cylinder? I think that is the main issue. have the key coded for the new lock cylinder?
Posted on: 2017/6/5 17:11
Matatk Re: vats
You would get a new key with the lock cylinder. You can retain the same VATS resistance, you just measure the pellet on the key and find out how many ohms.
But what we are suggesting is first try to clean and lubricate the cylinder. I also asked if you have an automatic transmission because there is a cable that is connected from the cylinder to the shifter that prevents the car from going out of park if the cylinder it not turned on.
Posted on: 2017/6/5 22:21
buna
7 Posts
i have tried cleaning and lube. before it was not unlocking it had some no starts just trun the key and nothing try a few hours later it would start. i took it to a tech that had it for two weeks never could get it to act up. the day i took it home and stoped at the store i get back an no start then two hours later it starts
Posted on: 2017/6/6 1:26
Matatk Re: vats
Did you try a second key? The pellets get worn down over time.
Posted on: 2017/6/6 2:01
buna
7 Posts
have not tried that yet, looked at this key and the pellet looks tight and not to worn.
Posted on: 2017/6/6 16:02
hcbph Re: vats
269 Posts
Doesn't matter what it looks like, it's how it's acting. Unhook the battery (just to be safe) and take a Q-tip with some alcohol in the cylinder and clean the contacts where the resistor on the key makes contact.
Now there is a way to test if you're getting a good contact or not. Again with the battery disconnected, drop the hush panel under the steering column. From near the bottom of the steering column before it goes through the firewall, there is a 2 strand wire with a connector on it (one is orange IIRC) that continues up behind the DIC. Unhook the connector so you can use the OHM meter to check continuity with the key in the ignition, 2 probes - 2 wires in the connector - see if you have a circuit and if the values match or not. With an OHM meter take a reading of the resistor on your key. Now put the key in the ignition (don't remember if had to turn the ignition on or not) and using the ohm meter probe the wires coming out of the column and see if you get the same resistance value (they should match). Play with the wheel, turn signals etc too and see if there's any change along the way (there shouldn't). If your readings are consistent then it's not likely the key or cylinder causing your problem.
If you change the cylinder, column etc., that resistor value must remain the same. Unless you use the dongle like I did, any new key will need to have a resistor with the same value as your existing one does or the car won't start. Also if you have any new keys made, check them with an OHM meter, I've gotten one where they cut the wrong blank, turned the ignition fine but wouldn't start the vehicle.
Hope that helps.
Posted on: 2017/6/6 19:22
Matatk Re: vats
Good troubleshooting info right there.
If you want some information on how the system works check here:
http://www.vatssucks.com/
Posted on: 2017/6/6 20:43
Matatk Re: vats
Any updates?
Posted on: 2017/6/15 0:35
buna
7 Posts
the update, i have missplaced the keys.
Posted on: 2017/6/15 2:00
hcbph Re: vats
269 Posts
Bummer.
Posted on: 2017/6/16 12:59
buna
7 Posts
i will find them its just, been a while since i have even thouht about the car. i do know thats it still in the garage
Posted on: 2017/6/16 18:56
