282 user(s) are online (251 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
Pocono87 air-fuel ratio
OHIO
9 Posts
Ok...here goes...I had a renegade intake put on my car...wether imagined or not,car seemed to run better,more power...had it dynoed...tech did 2 pulls...told me when rpm hit 4600-4700 power would drop...I ask if he knew what would cause this..he said it wasn't getting enough fuel to match air intake...any thoughts on how or what to do to fix this issue? thank you for any input
Posted on: 2017/7/2 1:12
teebee Re: air-fuel ratio
12368 Posts
A friend of mine, on another forum,put the Renegade manifold on his 82. He had to really work at it, but finally got the 82 to put out the power levels he was hoping for. If you are interested, I can put you in touch with him.
Posted on: 2017/7/2 13:59
Pocono87 Re: air-fuel ratio
OHIO
9 Posts
Yes that would be awesome and thank you
Posted on: 2017/7/2 22:24
rklessdriver Re: air-fuel ratio
What was the Air Fuel ratio when power dropped?
Posted on: 2017/7/3 17:30
bogus Re: air-fuel ratio
That's the computer... and the throttle bodies...
The first thing you should do is upgrade the ECU from the 1984 part to the 1987 Pickup truck part. There is some wiring changes, but the speed of the computer and its ability to tune faster is valuable.
Check fuel flow... the flow is rated for that kind of RPM where the engine dies naturally... you might need a bit more pump, but not a lot more.
The other trick is to use the 454 big block throttle bodies. They flow much better.
Posted on: 2017/7/3 19:39
Matatk Re: air-fuel ratio
Repin the ECM to a newer (faster) model and have a custom tune made. That should do it.
Posted on: 2017/7/4 1:13
