122 user(s) are online (90 user(s) are browsing Forums)
pianoguy Question about ZF bellhousing
When I was taking off the driver's side cat tonight, I noticed a round hole in the side of the bellhousing, maybe about the size of a quarter - it is clearly supposed to be there, but is just open. Should there be some kind of plug or cover for it?
Posted on: 2008/3/26 3:25
bogus Re: Question about ZF bellhousing
hm... I don't remember... I would have to get under there, and you know, it's dark.
CC might have a more recent experience...
Posted on: 2008/3/26 3:56
LD85 Re: Question about ZF bellhousing
Indianapolis, Indiana
784 Posts
No plug available that I have ever seen, it's a site hole to check the clutch wear.
Posted on: 2008/3/26 17:15
2005/Z51
pianoguy Re: Question about ZF bellhousing
Thanks - just seems odd that it wouldn't have some kind of plug or something. I did a quick search for any reference to it in the Woodchuck's Handy Guide (FSM), but didn't find anything.
Posted on: 2008/3/26 21:57
CentralCoaster Re: Question about ZF bellhousing
Don't worry about it. There are some cars that don't even have an inspection cover, and the entire bottom of the flywheel is exposed.
Posted on: 2008/3/27 18:17
