108 user(s) are online (84 user(s) are browsing Forums)
Livin_the_dream Spring Cleaning
robesonia , pa
516 Posts
Look at what I found! About 4 inches of leaves and crud! I even found a styrofoam cup and an aluminium foil lid! My car had no overheating problems , however the temps ran higher than I liked. It also took longer to cool than I thought it should when I bought the car last May.You may want to add this to your spring projects!
cleaned this with a vacuum and crevice tool
Photobucket
Photobucket
Posted on: 2008/3/9 3:36
biggrizzly Re: Spring Cleaning
I did mine for the first time a couple years ago. I had around 100K miles on the car at the time. I also found a ton of things you would expect on a treasure hunt game including a dried Frog Carcass!!
Posted on: 2008/3/9 3:44
pianoguy Re: Spring Cleaning
Mine's not too bad, but I'm gonna blow it out with compressed air anyway, as long as I'm doing all my other projects. I may put one of those screens on, too.
Posted on: 2008/3/9 4:24
crash Re: Spring Cleaning
WRIGHT CITY MO 63390
977 Posts
Photobucket
Photobucket
CLEAN THAT A/C CONDENSOR ALSO THAT LOWER RIGHT CORNER IS FILTHY IF THATS A/C OIL U BETTER CHECK THE A.C OPERATION AND THAT AREA FOR A LEAK
Posted on: 2008/3/26 11:55
LD85 Re: Spring Cleaning
Indianapolis, Indiana
784 Posts
Same stuff every year, leaved, butts, straws, pine needles.
Posted on: 2008/3/26 17:32
2005/Z51
Livin_the_dream Re: Spring Cleaning
robesonia , pa
516 Posts
I already did and I agree - I am thinking condensor as the A/C does have a slow leak down. Been reading up in the helms. The A/C has already been converted to R134A
Photobucket
Posted on: 2008/3/26 23:32
