183 user(s) are online (155 user(s) are browsing Forums)
brian i think i made a boo boo
193 Posts
Ok, so recently i washed my 1988 corvette because it was nasty dirty. Well washing it I also sprayed the gas cap area down with high pressure water. I did not think anything of it till the other day i started it up to move it, well when i reved it up it would backfire at like 3000-3500 rpm's. Could this be because I got water in the gas tank and if so how big of problem could I be facing here.
Posted on: 2008/3/30 7:57
CasetheCorvetteman Re: i think i made a boo boo
Well i doubt it, but if you think thats an issue then drain the tank and refill it with new fuel.
Ive hosed in there every time i wash the car and havent had that issue yet!!
Posted on: 2008/3/30 8:52
brian Re: i think i made a boo boo
193 Posts
ok im just checking. im not driving the car cause i have to do work on it before it is driveable but sometimes i like to go to it start it up and rev it up. but yeah it was back fireing around 3500 RPM's its not the opti i dont think so atleast cause i didnt spray down the engine. ill start it up tomorrow cause i need to take it to my new house and give it another rev up. and see
Posted on: 2008/3/30 9:11
Well i know for a 190% fact its not the optispark cause you dont have one.
Posted on: 2008/3/30 9:22
193 Posts
oh lol. good point. i wasnt sure everyone is always talking about there opti so i figured i did have one. what is it anyways well were on that subject.
Posted on: 2008/3/30 9:45
Optical triger system in the distributor on the 92-96 LT1 and LT4.
Despite the rumours, washing the engine wont hurt it either as long as youre smart about it, cause mine is still going strong.
Posted on: 2008/3/30 10:10
193 Posts
so wait why dosent my distributor have one?
Posted on: 2008/3/30 10:40
Cause yours is 88, and its an L98, has a conventional distributor
Posted on: 2008/3/30 12:08
193 Posts
aw ok. im just getting into the engine technical stuff. i know the basics of the engine and i know how it works.
Posted on: 2008/3/30 12:12
xccter Re: i think i made a boo boo
Downtown Annapolis, MD
461 Posts
Here's a pretty good overview of the opti.
http://www.delteq.com/products_opti.htm
Posted on: 2008/3/30 14:18
ยด71 350/270 L48 Coupe
NCRS #48337
Midnight85 Re: i think i made a boo boo
Streator, IL.
264 Posts
Like Case said, I doubt if you got water in the tank but a cheap cure would be to put a couple bottles of Heet in the tank, it will help get rid of the water if there is any.
Posted on: 2008/3/30 14:19
