157 user(s) are online (121 user(s) are browsing Forums)
[IMG]http:/...
DaleD Good day today.
Cuyahoga Falls, Ohio
1389 Posts
The guy I know at the body shop helps me out with some simple stuff. I had him do the passenger door panel in my car because he's good, and cheap!
So, I go to pick it up and he tells me: "That's turning into a nice little car." He saw it right after I bought it. Made me feel pretty good. So, I drove it to work.
It's 65* here, the car is running good, the new stereo sounds great, and I got to show it off to coworkers.
My little 87 is coming along nicely.
- I've replaced the wheels and tires, good reviews here at work. Especially from the guy that owns an 84 Corvette.
- New stereo, head unit, speakers and wires.
- New passenger door panel.
- New hood emblem.
- I have new KYBs to be put on before I have it aligned.
- I have a new/used oil pan, gaskets and bolts to be put on.
- I have a tune up kit, wires, plugs, rotor, cap that I'm going to do this spring.
- A duplicolor kit to paint the calipers red.
By summer time, I'll be ready!
Posted on: 2008/4/8 17:42
skirlin Re: Good day today.
Caledonia Michigan
277 Posts
Go Dale Kudos on the body shop connection. :thumbright:
Posted on: 2008/4/8 18:00
pappyfreebird Re: Good day today.
1028 Posts
sounds groovy.... right now id be happy jus ta have the 60s temp...but that vet sounds trippin
Posted on: 2008/4/8 18:01
crash Re: Good day today.
WRIGHT CITY MO 63390
977 Posts
IT MAKES YOU FEEL GOOD WHEN THINGS START COMING TOGETHER
WHEN YOU DO THE OIL PAN YOU MIGHT AS WELL PUT A OIL PUMP IN IT TOO
Posted on: 2008/4/9 2:25
WrenchmanT Re: G
44 Posts
I
Posted on: 2008/4/15 12:13
TommyT-Bone Re: Good day today.
33777 Posts
Man with a plan.
Posted on: 2008/4/15 12:22
