239 user(s) are online (199 user(s) are browsing Forums)
movnviolation Wheel hub cover locking bolt stripped, help
Hesperia, Calif
188 Posts
I am trying to take the wheels off so I can change out the rear bearing.
the security bolt that holds the cover on is stripped. It is hardened steel so I can not drill and use easy out. Any ideas? Thanks!
Posted on: 2008/4/25 20:43
Mods
Matatk Re: Wheel hub cover locking bolt stripped, help
Do you mean the head of it is stripped, as in the security part?
Do you have a welder? If you do, try welding a rod on that you can turn with a pair of pliers. If not, try griding out some of the center of the head to make a slot for a screwdriver.
Posted on: 2008/4/25 22:30
movnviolation Re: Wheel hub cover locking bolt stripped, help
Hesperia, Calif
188 Posts
Got it, neighbor had same bits that worked on hardened steel. Gotta get some! Thanks
Posted on: 2008/4/25 22:47
Mods
Glad it worked out!
Posted on: 2008/4/25 22:51
