movnviolation | Wheel hub cover locking bolt stripped, help | ||
I am trying to take the wheels off so I can change out the rear bearing.
the security bolt that holds the cover on is stripped. It is hardened steel so I can not drill and use easy out. Any ideas? Thanks! |
Posted on: 2008/4/25 20:43
Mods AFR 180 comp. heads w/ heavy springs. TPIS ZZ409 cam w/ 1.6 roller rockers, TPIS long tube headers, Miniram, 52mm throttle body, 24 lb Bosch injectors, Level V TPIS chip |
Matatk | Re: Wheel hub cover locking bolt stripped, help | ||
Do you mean the head of it is stripped, as in the security part?
Do you have a welder? If you do, try welding a rod on that you can turn with a pair of pliers. If not, try griding out some of the center of the head to make a slot for a screwdriver. Matthew |
Posted on: 2008/4/25 22:30
movnviolation | Re: Wheel hub cover locking bolt stripped, help | ||
Got it, neighbor had same bits that worked on hardened steel. Gotta get some! Thanks
Posted on: 2008/4/25 22:47
Glad it worked out!
Matthew |
Posted on: 2008/4/25 22:51
