160 user(s) are online (109 user(s) are browsing Forums)
teebee, more...
rg86vet code 32
15 Posts
86 vet has been running fine, tonight on interstate running constant 70 mph for 30 miles ,service light comes on ,stays on for about 25 min until i got off at exit and opened her up , the light then went out. has not came back on , should i be worried?
Posted on: 2008/5/11 2:08
bogus Re: code 32
20860 Posts
I need to confirm what a code 32 means.
Posted on: 2008/5/11 2:13
rg86vet Re: code 32
15 Posts
egr issue
Posted on: 2008/5/11 2:25
bogus Re: code 32
20860 Posts
that could be one of 2 things...
1) the solinoid that fires up the egr
2) the egr valve itself
now, considering it took forever to light up, I would say it's the valve itself.
Dollars to donuts, it's OEM, so a replacement would not be all bad. It's just labour intensive.
Posted on: 2008/5/11 2:43
rayquayle Re: code 32
139 Posts
3) EGR Temp Switch connector or wire (in pipe between intake and passenger side exhaust manifold, has single black wire and plugs into connector behind distributor)
Posted on: 2008/5/11 6:28
Edited by rayquayle on 2008/5/11 16:55:11
Ray Quayle in England
'86 Indy PaceCar, 4+3
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
rg86vet Re: code 32
15 Posts
is it ok to drive with this problem , since the car seems to be running ok?
Posted on: 2008/5/11 12:47
CasetheCorvetteman Re: code 32
Its fine mate, drive the arse off it. You wont hurt anything.
Posted on: 2008/5/11 12:55
rg86vet Re: code 32
15 Posts
On The Right Side Of The Engine Where The Tube With The Silver Insulation. The Wire That Goes Into The Ceramic Piece Is Loose. The Wire Goes Behind The Distributor. Can I Unplug The Wire And Screw That Wire Into The Ceramic. Will It Or Not Screw In. But I Can Tell You The Wire Is Very Loose. Could That Throw A Code 32?
A Loose Wire Still Connected But Alot Of Movement
Posted on: 2008/5/11 16:38
bogus Re: code 32
20860 Posts
GM makes a connector to replace that loose one.
EGR does a one thing... it lowers combustion temperatures by introducing exhaust gases.
That results in two things: lowering NOx emissions and reducing the engines propensity to detonation.
Posted on: 2008/5/11 18:31
SpeedHound Re: code 32
Social Circle, GA
119 Posts
32 is an annoyance. You can try and fix it but it may just come right back on. I've got a car at the shop now that I am working on. Go through the directions in the FSM to test everything. I get to the end because everything tests as being fine. What does the book say? "The circuit is fine" It offers no suggestions as to why the code comes on beyond that if everything tests fine. So basically either GM is saying screw you to the Imperial Federal Government or they just want your money to diagnose a non issue. Don't sweat it unless you have to pass emissions, then get the code removed via a chip burn.
Posted on: 2008/5/13 2:36
Trey
www.speedhound.com
benny42 Re: code 32
Houston, Tx
91 Posts
The answer to your question in post#8 is
yes. That switch has failed. The replacement
for "corvette" isn't always in stock near me,
but the "camaro" part usually is. The camaro
switch has a longer wire and cost a couple of
dollars more. Both my T.P.I. cars have done that.
benny
Posted on: 2008/5/14 0:36
