rg86vet | code 32 | ||
86 vet has been running fine, tonight on interstate running constant 70 mph for 30 miles ,service light comes on ,stays on for about 25 min until i got off at exit and opened her up , the light then went out. has not came back on , should i be worried?
Posted on: 2008/5/11 2:08
bogus | Re: code 32 | ||
I need to confirm what a code 32 means.
Posted on: 2008/5/11 2:13
rg86vet | Re: code 32 | ||
egr issue
Posted on: 2008/5/11 2:25
that could be one of 2 things...
1) the solinoid that fires up the egr 2) the egr valve itself now, considering it took forever to light up, I would say it's the valve itself. Dollars to donuts, it's OEM, so a replacement would not be all bad. It's just labour intensive. |
Posted on: 2008/5/11 2:43
rayquayle | Re: code 32 | ||
3) EGR Temp Switch connector or wire (in pipe between intake and passenger side exhaust manifold, has single black wire and plugs into connector behind distributor) |
Posted on: 2008/5/11 6:28
Edited by rayquayle on 2008/5/11 16:55:11 |
Ray Quayle in England '86 Indy PaceCar, 4+3 NCM Founder #2896 NCM Lifetime #672 Graduate of Gordon's School |
is it ok to drive with this problem , since the car seems to be running ok?
Posted on: 2008/5/11 12:47
CasetheCorvetteman | Re: code 32 | ||
Its fine mate, drive the arse off it. You wont hurt anything.
Posted on: 2008/5/11 12:55
On The Right Side Of The Engine Where The Tube With The Silver Insulation. The Wire That Goes Into The Ceramic Piece Is Loose. The Wire Goes Behind The Distributor. Can I Unplug The Wire And Screw That Wire Into The Ceramic. Will It Or Not Screw In. But I Can Tell You The Wire Is Very Loose. Could That Throw A Code 32?
A Loose Wire Still Connected But Alot Of Movement |
Posted on: 2008/5/11 16:38
GM makes a connector to replace that loose one.
EGR does a one thing... it lowers combustion temperatures by introducing exhaust gases. That results in two things: lowering NOx emissions and reducing the engines propensity to detonation. |
Posted on: 2008/5/11 18:31
SpeedHound | Re: code 32 | ||
32 is an annoyance. You can try and fix it but it may just come right back on. I've got a car at the shop now that I am working on. Go through the directions in the FSM to test everything. I get to the end because everything tests as being fine. What does the book say? "The circuit is fine" It offers no suggestions as to why the code comes on beyond that if everything tests fine. So basically either GM is saying screw you to the Imperial Federal Government or they just want your money to diagnose a non issue. Don't sweat it unless you have to pass emissions, then get the code removed via a chip burn.
Posted on: 2008/5/13 2:36
benny42 | Re: code 32 | ||
The answer to your question in post#8 is
yes. That switch has failed. The replacement for "corvette" isn't always in stock near me, but the "camaro" part usually is. The camaro switch has a longer wire and cost a couple of dollars more. Both my T.P.I. cars have done that. benny |
Posted on: 2008/5/14 0:36
