jsup | Analytic software, which one? | ||
What do you guys use for analytics of the ECM?
Datamaster is about $100. Others are free. What works, that's the most important issue. Thanks |
Posted on: 2008/5/17 3:53
CasetheCorvetteman | Re: Analytic software, which one? | ||
Datamaster is WORTH $100, the others i dont reckon are worth the download.
Thats just me, but Datamaster is pretty damn good. |
Posted on: 2008/5/17 4:36
CentralCoaster | Re: Analytic software, which one? | ||
Any of you guys used Ease?
Posted on: 2008/5/18 8:56
No, cant say ive heard of it, is it any good?
Posted on: 2008/5/18 9:36
Dads90 | Re: Analytic software, which one? | ||
Datamaster gives you 20 scans for free when you first download it. It works great, I wasted 6 scans trying to figure it out, after that it is great, got the USB cable online.
Posted on: 2008/5/22 3:56
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. |
BigT | Re: Analytic software, which one? | ||
Hi Guys,
I acquired a 1987 C4 about a year ago and I am still finding may way around it. I have changed the ignition wires and the oil but nothing more ambitious than that so far. I would really be interested in acquiring some analytic software. I tried to Google Datamaster but all I got was links to this site. Any idea where one would go to buy the software and the cable? Sorry for the novice inquiry in amongst your learned discussion. Thanks. |
Posted on: 2008/5/23 16:01
See if this helps. http://www.aldlcables.com/sc/details.asp?item=aldlbareu
Posted on: 2008/5/25 5:16
Oh, check out the software tab.
Posted on: 2008/5/25 5:17
Mate no need to be sorry at all, youre more than welcome. Youll want to look here: http://www.ttspowersystems.com/DataMaster.html The user manual is here: http://www.ttspowersystems.com/software/dm350/Docs/DM32MAN.PDF And this is for your 87: http://www.ttspowersystems.com/software/dm350/32/setup-32.exe This cable: From here: http://www.aldlcables.com/sc/details.asp?item=aldlobd1 This cable: From here: http://www.aldlcables.com/sc/details.asp?item=aldlobd1u Or the cable listed by Dads90 ubove, which is the same without the molded 12 pin plug. (i think they are the same price these days, not sure.) |
Posted on: 2008/5/25 5:33
LT4BUD | Re: Analytic software, which one? | ||
I have an Ease Code Reader. Great product but was way overpriced...lower priced units would do the same functions IMHO their products are high quality but also too high $$ |
Posted on: 2008/5/26 14:18
Hello all,
Following Casey's advice, I sent away for the Datamaster. I got it from TTS Power Sytems through Andrew Mattei at AKM Electronics which went very smoothly. Thanks, Casey. All I have to do now is figure out what the heck I am looking at. One question right up front is that I got an Error Code 32, related to the EGR system. I looked that up in the Service Manual and trouble shooting it involves an array of tests using a scanner and vacuum guage, neither of which I have. I am at a bit of a loss knowing where to start. The car is running fine and I don't think I would have known about this except for running the Datamaster. I guess I could remove the plenum and start replacing parts. Do any of you learned gentlemen have any suggestions for the novice? If I have posted this in the wrong area, please forgive me and let me know where it should go. Thanks, Tony |
Posted on: 2008/8/5 14:35
