DUBIE | LTPWS | ||
LTPWS light remains on after start--goes out after 100 yards and then comes back after a few miles. First started after all tires changed. Any ideas.
Posted on: 2007/5/4 1:27
Rabbit | RE:LTPWS | ||
Apparently a sensor was damaged when the tires were changed.
You can determine which one by using the DLC to interrogate the system. What year do you have? |
Posted on: 2007/5/4 14:49
red_johnny | RE:LTPWS | ||
Apparently a sensor was damaged when the tires were changed. |
Posted on: 2007/5/7 20:02
DUBIE | ltpws | ||
It's a 1991 l-98
Posted on: 2007/5/14 20:35
Use this site http://www.grandsportregistry.com/techtips/service_ltpws.htm
You will have to use pins A & B for 5 & six as indicated on the info sheet. That's the only difference I can think of. Are you familiar with pulling codes? If not go here....http://www.corvettephotographs.com/c4vettes/index.htm |
Posted on: 2007/5/15 21:19
