173 user(s) are online (129 user(s) are browsing Forums)
DUBIE LTPWS
NY
33 Posts
LTPWS light remains on after start--goes out after 100 yards and then comes back after a few miles. First started after all tires changed. Any ideas.
Posted on: 2007/5/4 1:27
Rabbit RE:LTPWS
Sonoma, Ca
11 Posts
Apparently a sensor was damaged when the tires were changed.
You can determine which one by using the DLC to interrogate the system.
What year do you have?
Posted on: 2007/5/4 14:49
red_johnny RE:LTPWS
I agree, either that or a wire got damaged.
Posted on: 2007/5/7 20:02
DUBIE ltpws
NY
33 Posts
It's a 1991 l-98
Posted on: 2007/5/14 20:35
Rabbit RE:LTPWS
Sonoma, Ca
11 Posts
Use this site http://www.grandsportregistry.com/techtips/service_ltpws.htm
You will have to use pins A & B for 5 & six as indicated on the info sheet.
That's the only difference I can think of. Are you familiar with pulling codes?
If not go here....http://www.corvettephotographs.com/c4vettes/index.htm
Posted on: 2007/5/15 21:19
