josephf31 | 1991 Rear Hatch Glass question | ||
When you remove the rear hatch glass from a 1991 Coupe, does the painted top piece in back of the halo come off with it?
If so can the painted piece be removed and exchanged or is a part of the hatch assembly? I'm looking at replacing my (white) one with one from a yellow car and trying to figure out if I can avoid painting etc. Thanks all! |
Posted on: 2008/6/28 21:07
2002 Magnetic Red C5 6 spd LS1 convertible |
bogus | Re: 1991 Rear Hatch Glass question | ||
I am sure it's a different part.
Open the hatch and check for bolts. I would expect studs on the plate coming through holes in the glass. I have never done it, but that's my guess... |
Posted on: 2008/6/28 21:19
josephf31 | Re: 1991 Rear Hatch Glass question | ||
According to the FSM the hinge and glass are "serviced as a unit". Still, I'm not totally sure it can't come apart, it looks like it should but if so it isn't obvious -- wondering if anyone has done this...or if I'll just have to look for a white hinge or paint a different one...thanks all...
Posted on: 2008/6/29 0:43
gee... if it's serviced as a unit, I would suspect not. I bet then it's glued on with some industrial strength super epoxy...
Posted on: 2008/6/29 3:32
RollaMo-LT4 | Re: 1991 Rear Hatch Glass question | ||
Trivia Winner
Yes, that panel is glued to the glass. You will probably break the glass before you ever got them apart.
Posted on: 2008/6/29 4:14
1996 Torch Red LT4 2000 Chevy Silverado 2008 Harley-Davidson XL1200C (Sold) 2009 Harley-Davidson FXDF Fat Bob |
Jeffvette | Re: 1991 Rear Hatch Glass question | ||
You can separate it. It's GM's super strength adhesive that holds it together.
Posted on: 2008/6/29 4:52
I would paint it.
Posted on: 2008/6/29 21:50
Woodstock | Re: 1991 Rear Hatch Glass question | ||
You can separate it. It's GM's super strength adhesive that holds it together. I guess there is an irony smilie missing. On my last 4 rear-windows the hinge-plate almost fell off by itself after loosening those weird long-hole locking plates. |
Posted on: 2008/6/29 22:05
91 convertible |
