137 user(s) are online (61 user(s) are browsing Forums)
josephf31 1991 Rear Hatch Glass question
New Jersey
375 Posts
When you remove the rear hatch glass from a 1991 Coupe, does the painted top piece in back of the halo come off with it?
If so can the painted piece be removed and exchanged or is a part of the hatch assembly? I'm looking at replacing my (white) one with one from a yellow car and trying to figure out if I can avoid painting etc.
Thanks all!
Posted on: 2008/6/28 21:07
bogus Re: 1991 Rear Hatch Glass question
I am sure it's a different part.
Open the hatch and check for bolts. I would expect studs on the plate coming through holes in the glass.
I have never done it, but that's my guess...
Posted on: 2008/6/28 21:19
josephf31 Re: 1991 Rear Hatch Glass question
New Jersey
375 Posts
According to the FSM the hinge and glass are "serviced as a unit". Still, I'm not totally sure it can't come apart, it looks like it should but if so it isn't obvious -- wondering if anyone has done this...or if I'll just have to look for a white hinge or paint a different one...thanks all...
Posted on: 2008/6/29 0:43
gee... if it's serviced as a unit, I would suspect not. I bet then it's glued on with some industrial strength super epoxy...
Posted on: 2008/6/29 3:32
RollaMo-LT4 Re: 1991 Rear Hatch Glass question
Trivia Winner
Rolla, Missouri
422 Posts
Yes, that panel is glued to the glass. You will probably break the glass before you ever got them apart.
Posted on: 2008/6/29 4:14
1996 Torch Red LT4
2000 Chevy Silverado
2008 Harley-Davidson XL1200C (Sold)
2009 Harley-Davidson FXDF Fat Bob
Jeffvette Re: 1991 Rear Hatch Glass question
You can separate it. It's GM's super strength adhesive that holds it together.
Posted on: 2008/6/29 4:52
I would paint it.
Posted on: 2008/6/29 21:50
Woodstock Re: 1991 Rear Hatch Glass question
Bremen/Germany
369 Posts
I guess there is an irony smilie missing.
On my last 4 rear-windows the hinge-plate almost fell off by itself after loosening those weird long-hole locking plates.
Posted on: 2008/6/29 22:05
91 convertible
