190 user(s) are online (145 user(s) are browsing Forums)
kelley tried to start by itself
thomasville ga
122 Posts
MY 94,,,i started it and moved it, pulled key out of ignition, was doing stuff and the started motor started turning over,,,, i ran to get battery wrench and pull terminal, it was still turning over when i did that,??? any one got an idea??
Posted on: 2008/7/3 15:01
CSS996 Re: tried to start by itself
Mega Guru
Central PA
3644 Posts
Some kinda short in the 'lektrical system?
My daughter's Suzuki Esteem got about a gallon of water inside of it one evening after a heavy rain. We went out the next morning, and the lights were on. Couldn't turn them off.
We unhooked the battery, drained the car, and let it dry out for a few days, and that solved it. A little different than your problem, most likely, but anyway...
Something is screwy, that's for sure!
You don't have any small children with a knack for auto theft around, do ya?
Posted on: 2008/7/3 15:27
Currently "Between Vettes".
pappyfreebird Re: tried to start by itself
1028 Posts
back in 86-88 the chevy impalas were noted fer startin on fire cause the starter would jus take off...1st hand look at one burn ...it were in my fuggan drive way (parked close n blockin both my doors)drunkin brutha rolled up n went ta sleep...said woke up to car turnin over n was very hot then shmoke started to billow ...long story short it burnt up in my driveway...but seems were fairly commin (info came from firemayun)
Posted on: 2008/7/3 16:20
red_johnny Re: tried to start by itself
Might be a puter problem? We had that issue in the army a few years back with the Hummers, the control box (computer) had to be replaced on a TON of them. I actually saw it happen first hand. I was walking down the line and getting all of them straight so we would have 1 guy in one and 1 in another and so forth. Well after we get 1 good we move the driver down to the next, anyway, I am walking down to the next row of vehicles and was about to start guiding one guy on line when I hear a truck start and it kept turning over so I run down there yelling for the driver to knock it off when I discover there is no driver and the switch was off! So we ripped off the battery cable. It was a strange experience for sure.
Posted on: 2008/7/3 18:42
kelley Re: tried to start by itself
thomasville ga
122 Posts
had an idea was the ignition starter switch,well got to it and unplugged ALL the wires to it,touched battery cable back to see if starter was disconecter ,,NOT ,starter kept turning,,so i`m back to what now.its haunter,,
Posted on: 2008/7/5 16:33
bogus Re: tried to start by itself
it ain't the computer. It has NOTHING to do with the starter.
I would check the ignition switch under the steering column.
Posted on: 2008/7/5 18:40
thomasville ga
122 Posts
thats the one we checked, in fact took all the wires off touched battery and starter turned over,key in my pocket.
Posted on: 2008/7/5 20:22
CentralCoaster Re: tried to start by itself
If the starter solenoid 12V input is shorting to another 12V wire somewhere...
Or perhaps a really fubar'd solenoid could short internally?
Get a look underneath at the starter wiring, see if anything's melted.
Posted on: 2008/7/5 20:54
thomasville ga
122 Posts
where do you put jackstands,am useing factory jack, on grass no less,,so i have been working carefully trying to work the top first,
Posted on: 2008/7/5 21:56
whoa... dude... don't do that on grass. Drive it to a parking lot somewhere.
Just avoid the grass. The stands will sink right into the ground. It's not safe.
Read this, too: Towing and Jacking Your C4.
Posted on: 2008/7/5 22:14
Totally agree, in fact thats how the damage on my van happened, my brother jacked up the van in his yard and the car slipped off the jack. I dunno if it was the jack sinking or what but it fell none the less.
Posted on: 2008/7/5 22:17
thomasville ga
122 Posts
thank you for the jacking cite,, thats ok it broke over the septic tank so their is hard under it, ,i know,,, planking and cribbing will be used,and no work will be done just looking,
Posted on: 2008/7/5 23:50
JUST BE CAREFUL!!!!!!!
Posted on: 2008/7/6 20:07
thomasville ga
122 Posts
it started raining,,,,,it goes to a real mechanic tomorrow, all i can figure is the started shorted out ,i`ll know more next week
Posted on: 2008/7/6 22:43
I would rather money spent at a mechanic than at the ER.
Good move!
Posted on: 2008/7/7 1:51
Randyj75 Re: tried to start by itself
MD
129 Posts
I had this happen to me one day while working on the stereo system of my '82 Mustang. The starter solenoid shorted out and the engine started to turn over slowly as I was sitting in the car. This is why you should always disconnect the battery before doing any electrical work. I changed out the solenoid, and the car was fine, no melted wires.
Randy
Posted on: 2008/7/7 3:44
Notorious Re: tried to start by itself
Yep, solenoids can definitely do this. I've seen it more than once.
Posted on: 2008/7/7 4:33
I hate sporks...
thomasville ga
122 Posts
thats what happned,just sort of scarey it started when no one was in car, could have burned the car down,,but fixed now,
Posted on: 2008/7/7 17:02
