Z51L9889 | 383 build finally underway | ||
My 89 has been sitting since December 2005 due to a blown head gasket. I've spent the time since then planning, saving money, and collecting parts for a 383 build. Finally, after all this time, I dropped my engine block and stroker kit off at the machine shop this morning for short block assembly.
Short block build specs are as follows: Callies Dragonslayer Crank Manley H-lite H-beam rods (6" long) Mahle flat top coated pistons (-5 cc reliefs) Bret Bauer cam (CompCams lobes) 230/242; .603/.586 w/ 1.6 rockers; 111.5 LSA Cloyes Street Roller timing set 4 bolt truck block; 0.005 piston to deck, .044 total quench 10.8 SCR with 65 cc heads Top end parts include AFR195 Eliminators that I am porting and a ported FIRST intake. I will have the heads (and perhaps the intake) flowed when the porting is complete. I haven't totally decided on the headers yet (4 into 1 vs tri-Y), but the exhaust will be full dual 2 1/2" minimum with an x-pipe and cats. I've run the combo through Engine Analyzer v. 3.3. Using the most conservative assumptions the program offers for dyno type and test speed, I'm getting 495HP @ 6000 and 510TQ @ 4000. If all goes according to the current plan, I should be ready to fire it up by labor day. |
Posted on: 2008/7/7 15:38
CentralCoaster | Re: 383 build finally underway | ||
Although if that engine analyzer is anything like desktop dyno, I would take the results with a grain of salt. I want to stroke mine, but I'm thinking more on the lines of ported TPI and vortec heads. I have to pass smog, which limits what I can do. Have you considered flowing the parts before porting too? |
Posted on: 2008/7/7 16:52
red_johnny | Re: 383 build finally underway | ||
Those would be great numbers. Cant wait to see what it really turns out.
Posted on: 2008/7/7 19:31
Matatk | Re: 383 build finally underway | ||
Sounds great - that's a long time to wait! Now *we* have to wait for pictures. Keep us posted.
Matthew |
Posted on: 2008/7/8 0:45
Z51L9889 | Re: 383 build finally underway | ||
Engine Analyzer is FAR more accurate than Desktop Dyno. I have both, and I was able to match the dyno data for original 350 combo within a couple of HP and lb-ft on EA with the proper curve shape. I could never get DD to give me the right curve shape. I double checked the EA data by putting it into Drag2000 and the predicted ET/MPH were nearly a perfect match to my best timeslip.
I tried to set the sim as conservatively as I could. I feel the combo should dyno above 400 RWHP/TQ if I get it built right..... I'll post updates as things come together. :thumbright: |
Posted on: 2008/7/8 2:56
bogus | Re: 383 build finally underway | ||
your best bet would be a ZZ383 short block with nice aluminum heads. A big ass cat and you will pass smog. |
Posted on: 2008/7/8 4:47
FATED | Re: 383 build finally underway | ||
The desk top HP estimates should be more accurate because it has all been done before. My sim puts my engine at 480 and a near identical build in a hot rod magazine dynoed at 420. I figure 420.
Posted on: 2008/7/8 12:55
1985, Performance Chip, hole in muffler, and other Mods |
