101 user(s) are online (66 user(s) are browsing Forums)
rsawyer84 tires for 84
Trenton MI
38 Posts
What are the tires from other c5 c6 etc will fit on on an 84, i see adds on craigs list and afraid to buy unless they will fit. i have the original rims and 16in tires now, what are my options?
Posted on: 2008/8/17 2:24
Matatk Re: tires for 84
22812 Posts
For C4s, 84-87 had the same offset. It changed and remained the same 88-96. C5 is also a slightly different offset than the later c4s. The later c4 and c5 rims will fit your car with adapters (don't use spacers). Unless you are getting a super price for the rims, I don't think it's worth it (because you have to buy adapters). You can go on ebay and get AFS or OE wheels that fit the particular offset for your year and have later wheel styles. I'd check into that if I were looking for new rims.
Good luck.
Posted on: 2008/8/17 4:11
jhammons01 Re: tires for 84
^^that's about it in a nutshell
Posted on: 2008/8/18 13:42
JonnyAngle Re: tires for 84
Minneapolis, MN
151 Posts
lakeshorewheelandtire.com
Click on Corvette Specials, excellent customer service.
Posted on: 2008/8/18 14:03
