biggrizzly | MSD Opti fresh air hose location | ||
The instructions say to drill a 3/16" hole into the fresh air duct. The duct is rubber and doesn't lend itself to a clean hole or nice looking factory type install.
You guys that installed the 92-93 MSD opti and had to install the fresh air line, where did you install it? |
Posted on: 2008/9/7 14:19
Notorious | Re: MSD Opti fresh air hose location | ||
The factory vents are indeed just a hole in the duct with a 90° plastic nipple stuck in the hole to put the hose onto. Find a suitable place and use a sharp bit, shouldn't be a problem.
Posted on: 2008/9/7 14:28
I hate sporks... |
biggrizzly | Re: MSD Opti fresh air hose location | ||
Notorious - where is the factory location? |
Posted on: 2008/9/7 14:36
On the accordion hose that goes between the MAF and the TB. The left, upper side at about the 10:30 position on the most forward ridge of the hose.
Posted on: 2008/9/7 14:56
I hate sporks... |
kelley | Re: MSD Opti fresh air hose location | ||
Posted on: 2008/9/7 15:56
BillH | Re: MSD Opti fresh air hose location | ||
On my 92, I put the fitting on the bottom of the accordion where you can't see it.
Posted on: 2008/9/7 16:04
bogus | Re: MSD Opti fresh air hose location | ||
you can also use a soldering iron to melt a hole in.
the trick is finding a good vacuum source to cycle the air correctly. the venting needs positive pressure to truly vent the opti. |
Posted on: 2008/9/7 20:35
Matatk | Re: MSD Opti fresh air hose location | ||
Posted on: 2008/9/7 22:14
Good idea Andy! MSD supplies a T fitting to get vacuum from the left side intake manifold. Good? |
Posted on: 2008/9/8 0:30
I teed in on the right side but it really dosen't matter. Both are good.
Posted on: 2008/9/8 0:56
