271 user(s) are online (215 user(s) are browsing Forums)
biggrizzly Which fuse to pull to disable AC?
I'm going to start the car up for the first time, here in the next few days and I need to remove the fuse for the AC system as it is not charged at this time.
There are two fuses on the panel on the right dash panel
One is the AC clutch and the other is the AC Controler. Do I need to pull both or just the clutch?
Any other fuse I need to pull to make sure I don't burn up the compressor or clutch?
Posted on: 2008/9/8 22:29
Notorious Re: Which fuse to pull to disable AC?
Pulling the one for the clutch is all that's necessary. Or you could just unplug the clutch.
Posted on: 2008/9/8 22:35
I hate sporks...
biggrizzly Re: Which fuse to pull to disable AC?
I owe you lots of beers!
I figured as well, but wanted to be sure.
Thanks
Posted on: 2008/9/8 22:37
TommyT-Bone Re: Which fuse to pull to disable AC?
33764 Posts
So many times I have I have come up with questions like this one and for some reason, if I don't read it, I'll never think of doing it. Thanks Hot Rod.
Posted on: 2008/9/8 23:24
Qack Re: Which fuse to pull to disable AC?
274 Posts
If there's no charge in the system, the pressure sensor should prevent the clutch from engaging. However, disabling the clutch is still a good idea.
Posted on: 2008/9/9 3:39
