111 user(s) are online (46 user(s) are browsing Forums)
GRIS, more...
biggrizzly Can I check TPS with standard probes from my DVOM?
Can I check TPS with standard probes from my Blue Point DVOM? or do I need to buy any special test probes?
I have searched up the process for doing this but it wasn't too clear exactly what I had to do. In one sentance it said to hook a scanner up to the diagnostic port under the dash and then in another sentance its saying to check the voltage with a VOM.
What's the chances when I installed TPS into my new throttle body it was magically set correctly? HA HA
I think this is the last thing I have to do before start-up unless you guys can think of some things I should go over before I turn the key?
I got most of the old gas out and put in my Toyota. The toyota loves 14 month old gas... no problem from the little beast. I put 5 gallons of brand new fresh high test in the Vette tonight. Getting ready
Posted on: 2008/9/9 4:13
bogus Re: Can I check TPS with standard probes from my DVOM?
paperclips might help get behind the rubber seals better.
Posted on: 2008/9/9 4:55
Jeffvette Re: Can I check TPS with standard probes from my DVOM?
Get the correct probes. I have seen to many people screw it up trying to improvise.
Posted on: 2008/9/9 5:28
CentralCoaster Re: Can I check TPS with standard probes from my DVOM?
I stab the wires in the same place every time. If you get about 4V at idle you stabbed the 5V wire instead of the ground.
Posted on: 2008/9/9 6:28
biggrizzly Re: Can I check TPS with standard probes from my DVOM?
Also - The FSM says that when installing a new throttle body or TPS that you need to hook up a "Tech-1" instrument so that the EBTCM can re-learn the throttle postion for proper ASR operation.
What's up with that? Is there a way to do this at home without a "Tech-1"?
Posted on: 2008/9/9 10:29
Qack Re: Can I check TPS with standard probes from my DVOM?
274 Posts
I was going to suggest you use a scanner to read throttle position -- guess I still will. You can read it with the ignition turned on but without starting the engine. I use an Actron CP9145 -- which worked great right out of the box and gives you a bunch of useful real-time info.
I'm pretty sure that the Tech 1 is GM's version of a scanner. It's used to read the throttle angle percentage.
Where in the FSM did you read that it was needed so the EBTCM can re-learn the throttle position? I can't find it in mine - also a '94. I'm on page 5E2-139.
Posted on: 2008/9/9 13:45
Its in the emmission book in one of the earlier sections. I'm at work so I can't find it now, but I still have it turned to the page, so when I get home I'll let you know.
I have been looking for a good scanner that will work on my 94. Do you suggest the Actron? or is there something better?
What's the price of something like that?
Posted on: 2008/9/9 14:33
joeld Re: Can I check TPS with standard probes from my DVOM?
I use a Actron CP9145 also. I bought this one about a year ago and have been satisfied with it so far. I have used Actron scanners for years with NO complaints. I also bought the adaptor cable to use with OBDI. But there are much better scanners on the market, for much more money! This one does just fine for my needs. It is a good value for a good tool IMO.
Posted on: 2008/9/9 18:38
274 Posts
I like the Actron because it cost me $94 new, including shipping -- I hit Amazon.com at the right time. And because it is a solid unit. And most of all, because I hooked it up to my '94 LT1 and it worked the first time!
Besides all of the error codes, it reads the following info on the '94, which gives me plenty of things to play around with.
There are plenty of scanners that do a lot more -- but they are a lot more expensive as well.
Group 1
ITEM Range of Values
Air Pump ON/OFF
AC Clutch ON/OFF
AC Request ON/OFF
BARO (V)
Battery (V)
LT Fuel Trim ON/OFF
LT Fuel Trim CL
LT Fuel Trim L Nominal 128
LT Fuel Trim R Nominal 128
CC ON/OFF SW ON/OFF
EVAP Duty (%) 0-100
Coolant (°F)
CYL ID
EGR Duty (%) 0-100
FC1 Relay ON/OFF
FC2 Relay ON/OFF
IAC Position
Idle REQ RPM
INJ L PW (mV)
INJ R PW (mV)
ST Fuel Trim L
ST Fuel Trim R
Knock RET (°)
Knock Sensor
Loop Status OPEN/CLOSED
MAF (gr/sec)
MAP ("HG)
IAT (°F)
O2S Left (mV)
O2S Right (mV)
Oil Temp (°F)
PNP Switch P/N
PRNDL Switch P/N
Run Time
Shift Sol A ON/OFF
Shift Sol B ON/OFF
Spark Adv
TCC Brake Sw
TCC Control
ICC Solenoid ON/OFF
Throttle (%) 0-100
TPS Sensor (V)
Veh Speed (MPH)
Group 2
Engine RPM
PROM ID
TCC Control
TCC Duty Cycle (%) 0-100
TCC Slip ON/OFF
Trans TMP (°F)
VEH Speed (MPH)
Posted on: 2008/9/10 1:02
WOW! That was a good price! I won't admit what I paid.
Posted on: 2008/9/10 2:17
