113 user(s) are online (87 user(s) are browsing Forums)
CentralCoaster Can't get the A/C to recharge with this stupid can.
I'm working on a Nissan Sentra, R134a system.
The A/C doesn't blow cold.
The compressor clutch engages in a/c mode, and never cycles, just stays on all the time.
I bought a can to top it off, the system will not pull any in. I tried every angle, shaking it, waiting, waiting, but it will not pull it in on the low side. The dummy guage on the can reads low if the a/c is running. Of course, it goes way up if I shut the a/c off, as the system pressure equalizes.
I'm wondering if I've got a defective can, but this stuff is $30 so I don't want to buy more just for fun.
The car had a front end collision a few years ago that may have damaged the condenser, and the A/C hasn't blown cold since then.
Posted on: 2008/9/12 16:59
Touringmike Re: Can't get the A/C to recharge with this stupid can.
Sussex,Wi
569 Posts
If compressor is constantly running, that usually indicates sufficient charge (on a GM anyway).
You do have the engine running, can upside down and shaking, and valve open while you're trying to down-load refrigerant, correct?
Posted on: 2008/9/12 17:25
´85 4+3
CentralCoaster Re: Can't get the A/C to recharge with this stupid can.
Yes! I also tied my shoes and washed my hands.
If the system had a proper charge I'd expect the compressor to cycle based on pressure, not run constantly.
Oh, and the lines get barely cold, but not like they should.
Posted on: 2008/9/12 17:34
NC Kid Re: Can't get the A/C to recharge with this stupid can.
North Carolina
1671 Posts
Posted on: 2008/9/12 17:40
Sussex,Wi
569 Posts
Doesn't seem right. Usually compressors won't engage with low refrigerant.
Does this system have a "Max" position selection that the compressor is always running?
Can you releave any pressure out of the low side?
A lot of pressure on the low side could indicate the orifice screen may be blocked/plugged, or the pressure sensor on the low side tube close to the condenser is hosed.
Posted on: 2008/9/12 17:51
´85 4+3
Danspeed1 Re: Can't get the A/C to recharge with this stupid can.
Mooresville, North Carolina
1121 Posts
The compressor will run with a minimum charge on most GM cars. I don't know if this is true of Nissan. But if it was a GM car, I would say if its not blowing cold, and the compressor is running, your probably at about 75%. You can try the hot water method. Dangerous if your not careful, but I do it all the time. Get a small bucket of hot water (sink hot, not stove hot). Put the can in the water so its 50% covered. Give it a couple of minutes to warm up, and then turn the valve to open it up. Should cause a higher pressure in the can forcing out the refrigerant into the already pressurized system. Good Luck,
DG
Posted on: 2008/9/30 15:37
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
1121 Posts
Are you using a manifold gauge set... you might want to see if the high and low side pressures are balancing....
DG
Posted on: 2008/9/30 15:38
1996 Ford Explorer
2009 Cadillac CTS-v
No, my guage set only works on R22.
That would be easy otherwise. On my vette awhile back those guages indicated the condensor actually plugged and prevented charging it, but I was able to clean it out.
I wonder if the condensor was damaged in the crash. Those are usually pretty cheap.
Posted on: 2008/9/30 16:41
