241 user(s) are online (200 user(s) are browsing Forums)
1st Gear: 2.52
2nd Gear: 1.52
- 13 Bolt ...
BrianCunningham [geek] can't save file in Windows Movie maker
I'm trying to make a movie of my latest autox and I can't get Windows Movie Maker to save the file.
I don't think it's a FAT32 issue.
I've done everything the same as I did last time.
As a matter of fact I've openned up old projects and they want save either. :confused:
Was there a recent update to Windows Movie Maker?
Thanks
Posted on: 2008/9/14 22:03
bogus Re: [geek] can't save file in Windows Movie maker
not that I know of... but it would not be the first time a security patch really fixed some things...
Posted on: 2008/9/14 22:30
BrianCunningham Re: [geek] can't save file in Windows Movie maker
I can save it as an AVI file, but it's a HUGE file.
Posted on: 2008/9/14 23:07
yuck. At least saving it as an AVI, can you then reopen it and save it as a WAV or whatever?
Posted on: 2008/9/14 23:18
I checked my Windows updates.
It seems that some haven't gone through....
Looks like you need to manually enable your firewall to let them through.
I just finished downloading SP3, and I'll see what happens after I do and update.
Posted on: 2008/9/15 1:06
hm... why would a firewall care about MS updates? Odd.
Posted on: 2008/9/15 2:26
CentralCoaster Re: [geek] can't save file in Windows Movie maker
I haven't used it recently, but never had issues.
Does it run through and encode the file and then just quit?
Posted on: 2008/9/15 4:21
I figured it out.
Seems my spyware was blocking the installation of ServicePack 3 for XP.
I had to put my computer into safe mode to get it to install.
After it was finished I could save my work.
Here's the video.
I took someone new to autoxing out for some instruction.
Posted on: 2008/9/15 13:10
