BrianCunningham | [geek] can't save file in Windows Movie maker | ||
I'm trying to make a movie of my latest autox and I can't get Windows Movie Maker to save the file.
I don't think it's a FAT32 issue. I've done everything the same as I did last time. As a matter of fact I've openned up old projects and they want save either. :confused: Was there a recent update to Windows Movie Maker? Thanks |
Posted on: 2008/9/14 22:03
bogus | Re: [geek] can't save file in Windows Movie maker | ||
not that I know of... but it would not be the first time a security patch really fixed some things...
Posted on: 2008/9/14 22:30
BrianCunningham | Re: [geek] can't save file in Windows Movie maker | ||
I can save it as an AVI file, but it's a HUGE file.
Posted on: 2008/9/14 23:07
yuck. At least saving it as an AVI, can you then reopen it and save it as a WAV or whatever?
Posted on: 2008/9/14 23:18
I checked my Windows updates.
It seems that some haven't gone through.... Looks like you need to manually enable your firewall to let them through. I just finished downloading SP3, and I'll see what happens after I do and update. |
Posted on: 2008/9/15 1:06
hm... why would a firewall care about MS updates? Odd.
Posted on: 2008/9/15 2:26
CentralCoaster | Re: [geek] can't save file in Windows Movie maker | ||
I haven't used it recently, but never had issues.
Does it run through and encode the file and then just quit? |
Posted on: 2008/9/15 4:21
I figured it out.
Seems my spyware was blocking the installation of ServicePack 3 for XP. I had to put my computer into safe mode to get it to install. After it was finished I could save my work. Here's the video. I took someone new to autoxing out for some instruction. |
Posted on: 2008/9/15 13:10
