rsawyer84 | quite it just a bit | ||
i put a new exhaust system on my vette, not a real expensive system ..notice its kinda loud. Are there some tricks out there to quite it just a bit?
Thanks in advance as always for any help suggestions. |
Posted on: 2008/10/3 2:03
84 Proud Owner |
CentralCoaster | Re: quite it just a bit | ||
Do a search for "exhaust inserts" or "exhaust baffles".
Some of them can be installed in the exhaust tips. |
Posted on: 2008/10/3 2:41
1Fast04Vert | Re: quite it just a bit | ||
Not sure what you have now. Couple of guys replaced the resonator with twin dynomax mufflers, or a magnaflow dual in and dual out. They said it made a world of difference.
These were on factory true dual LT1s. |
Posted on: 2008/10/3 2:49
bogus | Re: quite it just a bit | ||
that's an 84, so it has a single center pipe - the cat, that is.
Now, do you have a cat on that thing? |
Posted on: 2008/10/3 4:36
rsawyer84 | Re: quite it just a bit | ||
yes cat is still in place left when we put the new system on
Posted on: 2008/10/3 19:00
84 Proud Owner |
Then you might want to find a good/used/cheap pair of LT1 mufflers to put on it, but that might be too quiet. |
Posted on: 2008/10/4 2:34
hard to say... if the exhaust is too cheapo, it might just not be up to the job.
I found that the L98 is rather subdued anyway, due to the central cat. Even moreso with the pup cats used on 87-91's. Do you have smog testing in MI? If not, would be looking for an entire LT1 system... go nuts. Dual cats, dual everything. |
Posted on: 2008/10/4 4:34
