122 user(s) are online (75 user(s) are browsing Forums)
Also known as SMC.
The only issu...
rsawyer84 quite it just a bit
Trenton MI
38 Posts
i put a new exhaust system on my vette, not a real expensive system ..notice its kinda loud. Are there some tricks out there to quite it just a bit?
Thanks in advance as always for any help suggestions.
jpg  Rear.JPG (119.36 KB)
1673_48e57d68c9f03.jpg 640X480 px
Posted on: 2008/10/3 2:03
84 Proud Owner
CentralCoaster Re: quite it just a bit
Do a search for "exhaust inserts" or "exhaust baffles".
Some of them can be installed in the exhaust tips.
Posted on: 2008/10/3 2:41
1Fast04Vert Re: quite it just a bit
Not sure what you have now. Couple of guys replaced the resonator with twin dynomax mufflers, or a magnaflow dual in and dual out. They said it made a world of difference.
These were on factory true dual LT1s.
Posted on: 2008/10/3 2:49
bogus Re: quite it just a bit
20861 Posts
that's an 84, so it has a single center pipe - the cat, that is.
Now, do you have a cat on that thing?
Posted on: 2008/10/3 4:36
rsawyer84 Re: quite it just a bit
Trenton MI
38 Posts
yes cat is still in place left when we put the new system on
Posted on: 2008/10/3 19:00
84 Proud Owner
Then you might want to find a good/used/cheap pair of LT1 mufflers to put on it, but that might be too quiet.
Posted on: 2008/10/4 2:34
20861 Posts
hard to say... if the exhaust is too cheapo, it might just not be up to the job.
I found that the L98 is rather subdued anyway, due to the central cat. Even moreso with the pup cats used on 87-91's.
Do you have smog testing in MI? If not, would be looking for an entire LT1 system... go nuts. Dual cats, dual everything.
Posted on: 2008/10/4 4:34
