164 user(s) are online (136 user(s) are browsing Forums)
JimD U joints (driveshaft)
NJ
14 Posts
Do I have to drop the exhaust, and x member to remove the driveshaft. I need new U joints, thanks Jim.
Posted on: 2008/10/14 22:55
bogus Re: U joints (driveshaft)
20860 Posts
yes. You also will have to loosen the c-beam. I don't think there is enough room to drop the shaft with the beam in place.
Posted on: 2008/10/15 1:58
Jeffvette Re: U joints (driveshaft)
You can modify underneath to remove the drive shaft with out touching the C-beam.
Posted on: 2008/10/15 2:25
vetteoz Re: U joints (driveshaft)
Mine comes out the side fine without touching C beam.
Disconnect uni caps , slide shaft foward to clear yoke; requires wheels off ground so you can rotate diff yoke to free uni's.
Slide out and backover handbrake cable until front yoke free.
Slide foward and down to drop
Posted on: 2008/10/15 4:26
CentralCoaster Re: U joints (driveshaft)
I've worked on some C4s that did and some that don't.
Mine doesn't. There must be variations in how big the sheetmetal edges are under there. I assuming that's what Jeffvette is talking about trimmin down.
Posted on: 2008/10/15 15:27
