87vette | control panel | ||
well i followed all the steps and took apart my lcd display panel i found some bad solder joint and re soldered them i cleaned the circuit boards and reinstalled to my car nothing happed i give up trying to fix it i guess ill just save a little and buy one!
Posted on: 2008/10/31 17:32
87vette | Re: control panel | ||
anyone have a extra 87 lcd control panel working unit to donate or maybe let me have for a good deal?
Posted on: 2008/10/31 17:37
AKS_Racing | Re: control panel | ||
I had previously mentioned that I had a few tucked away in the attic so that you can give it a try and see if the LCD panel is really your issue.
Aaron |
Posted on: 2008/10/31 21:47
Serv,
Send me your contact info to my email ( aarkat@sbcglobal.net ), as it seems that I am not a registered user on the PM system on the guru. It showed two PMs, but won't let me get to them, or reply to them. Aaron |
Posted on: 2008/10/31 21:54
CentralCoaster | Re: control panel | ||
AKS, I can try and check out your account and see what's up, but I think it requires me to change your password to access it. Let me know. |
Posted on: 2008/10/31 22:15
CC, That is fine if you reset my password, just let me know when it has been done. Will I be able to reset the password once I am back logged in? Thanks, Aaron |
Posted on: 2008/11/1 3:10
