92 user(s) are online (61 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
BrianCunningham Economic Stimulus check
I went to the IRS's website to check it's status, Friday is the last date to inquire BTW, only find find the deposit to my back account shares the same date and amount of my tax return check.
Am I the only one that was expecting a separate check?
Posted on: 2008/11/27 3:09
CentralCoaster Re: Economic Stimulus check
There's another check?
At the beginning of this year I received the $600 one seperate from my tax refund.
Posted on: 2008/11/27 3:23
Ok, looks like the same deal as last year.
I didn't know you could file in October. I'll just wait until April.
Posted on: 2008/11/27 3:24
pianoguy Re: Economic Stimulus check
I get to write more stimulus checks?
Posted on: 2008/11/27 4:05
