200 user(s) are online (70 user(s) are browsing Forums)
Assembly Line Diagnostic Link
j3studio [Attempting The Impossible] Making Early Z51 C4 Suspension Compliance As Good As Possible
[1985, Z51, very stock]
So, in my continuing attempts at restoring but still driving my 1985, we come to a question of priorities. I'd like to make the suspension as compliant as possible within the original design limits.
My question is:
Which 24 year-old suspension components can be replaced to give the best return on achieving this goal?
The original Bilstein shocks have been replaced with exact replicas. The car has a reasonably current alignment (about 3,000 miles ago) and modern tires with about 16,000 miles on them.
Posted on: 2009/1/26 22:51
CentralCoaster Re: [Attempting The Impossible] Making Early Z51 C4 Suspension Compliance As Good As Possible
In front, the rubber bushings are bonded to the metal. This adds stiffness to the suspension.
I would recommend some polyurethane up here, if installed and lubed properly, it will be more compliant.
I would not recommend them however in the front sway bar end links, or anywhere in the back of the car.
What will your resto rules allow?
Posted on: 2009/1/26 23:34
BillH Re: [Attempting The Impossible] Making Early Z51 C4 Suspension Compliance As Good As Possible
Chainging the bushings may help, a little. But, you have Z51 springs on the car. Nothing but changing them will make a big difference.
Alignment has zip,zilch, nada to do with it.
Posted on: 2009/1/27 0:36
bogus Re: [Attempting The Impossible] Making Early Z51 C4 Suspension Compliance As Good As Possible
20878 Posts
For ride, you might get away with the base Delco shocks.
But I agree with Bill... you might want to swap springs. The thing is, once you get the car fully NCRS'd, then you can do this!!!
Posted on: 2009/1/27 4:50
The spring codes are probably part of ncrs.
Pry some off and glue them to a base spring.
If it makes you feel better, the 85Z is about 1/2 the rate of the 84Z.
Posted on: 2009/1/27 5:23
vetteoz Re: [Attempting The Impossible] Making Early Z51 C4 Suspension Compliance As Good As Possible
On the springs I have the codes is stamped into the spring itself.
Posted on: 2009/1/27 7:23
