185 user(s) are online (119 user(s) are browsing Forums)
Ramrod 96 Window Problem?
S. California
296 Posts
First off my RH side window wouldn't go up 2 wks later my LH side won't do anything either? Anything in patricular I should look at first?
Posted on: 2007/12/8 6:13
CasetheCorvetteman RE:96 Window Problem?
The relays/switches mate. Then the wiring.
Posted on: 2007/12/8 7:18
Ramrod RE:96 Window Problem?
S. California
296 Posts
I had the RH door panel off, ck'ed the motor and switch. Moving on to the LH side today. Are the relays behind the battery?
Posted on: 2007/12/8 17:21
bogus RE:96 Window Problem?
I will have to check the Helm manual to be sure.
Strangely enough, 99% of the time, when a power window fails on a late modle C4, it's the damned motor... try slamming the door. If the window starts working again, you have found the problem. The brushes get stuck up in the motor and that's about that. The slamming trick can free them up.
There is no servicing those parts, which sucks... at least none I am aware of.
Posted on: 2007/12/8 19:03
S. California
296 Posts
1996 LT-1
Ok, I'm not electricaly inclined so I approach things from a mechanical point of vieW. I can cycle the motors directly, so they both go up & down. When I turn the key on the Driver side sw. get warm, and the circuit breaker gets hot? When i unplug the circuit breaker, then plug it back in it arcs. If I disconnect the driver side switch it dosen't arc. Is my problem in the drivers side switch? I cant find a "Window Control Module" in the door s. Does this year have one, and where the h#ll is it and the relay??
Posted on: 2007/12/16 16:14
hm.... I will have to go digging through my helm manual.
Posted on: 2007/12/16 20:14
TommyT-Bone RE:96 Window Problem?
33768 Posts
One of mine gets stuck about every 6 months or so. This is not in the manual. I sit in the passeger seat and slam the door while holding the window switch in the direction you want it to go. This could go into the 101 things you can do before you have to repair something booklet. Might not work, but it is worth a try.
Posted on: 2007/12/16 20:27
Bad ground to the window motor.
Posted on: 2007/12/17 7:27
there are major grounds in either kick panel. I would check them.
Posted on: 2007/12/17 15:28
CentralCoaster RE:96 Window Problem?
When one fails, do they both fail? I'd be looking for something they both share, like the same power circuit.
Mine has a thermal fuse in there somewhere that if the system is pulling too much current, it will shut down the circuit for a while until it cools. This could be from bad motor windings, a partial short, bad thermal fuse, etc.
Posted on: 2007/12/23 2:51
