222 user(s) are online (100 user(s) are browsing Forums)
« 1 (2)
bogus Re: [UPDATE] Damned thing did it again...
20878 Posts
I replaced the wires today. I think that has resolved the miss.
It seemed to be running better.
If there is still an issue, it's a coil that fried when the wired sliced.
Posted on: 2009/2/9 5:39
BrianCunningham Re: [UPDATE] Damned thing did it again...
Whoohoo!
Posted on: 2009/2/9 13:35
20878 Posts
I still have a miss... it gets worse as the engine warms... I am wondering of a coil fried during the harness destruction.
Tomorrow night, I will hit this with my old school timing light. I will know it a wire is getting juice.
If not, then I have my issue!
Otherwise, I may have a dead wire or a dead coil.
Posted on: 2009/2/10 3:31
bogus Re: [FINAL UPDATE] Damned thing did it again...
20878 Posts
This should be the final update:
I found a couple of disconnected vacuum lines... they were for the climate control vents, on the right side. I fixed that then went looking for the miss.
And found it. #3 coil was dead. I found that one of pins in the socket got bent when the harness got yanked. I fixed that, installed these cool trick new brackets and proceeded to test fire the engine. Guess what? NO MORE MISS!
I am so excited.
I will post pics over the weekend.
Posted on: 2009/2/11 4:52
Calm Re: [FINAL UPDATE] Damned thing did it again...
Vancouver, Canada
608 Posts
Posted on: 2009/2/11 5:10
crash Re: [FINAL UPDATE] Damned thing did it again...
WRIGHT CITY MO 63390
977 Posts
SEE WHAT A LITTLE PERSISTANCE AND PATIENCE CAN DO. GOOD JOB ANDY.
Posted on: 2009/2/11 12:57
20878 Posts
it only takes time! I knew I would find it... but I had to just work through it... each solution raised it's own problems.
The thing was, the coil with the bad connector still seated... just not evenly! I didn't notice that until I started to focus on it.
Posted on: 2009/2/11 15:23
joeld Re: [FINAL UPDATE] Damned thing did it again...
Just catching up on this one. Good job
Posted on: 2009/2/11 23:04
xccter Re: [FINAL UPDATE] Damned thing did it again...
Downtown Annapolis, MD
461 Posts
I spent one whole break at work reading this thread.
Nice job tracking all that stuff down Andy. What a pita.
Mark
Posted on: 2009/2/12 0:59
ยด71 350/270 L48 Coupe
NCRS #48337
20878 Posts
the entire experience was a pain... I hope it continues to run ok.
It's been running quite well today...
Next up... a clutch.
Posted on: 2009/2/12 2:29
« 1 (2)
