139 user(s) are online (96 user(s) are browsing Forums)
CasetheCorvetteman Need some 30lb/hr injectors
Anyone got some for sale or able to get me some? My supplier is on holidays and i dont want to use someone else and have my pants pulled down over the price
Ford 30lb/hr will do, ive seen them as low as $239 USD for a set of 8, but if anyone else has something they would like to recomend then please do.
Posted on: 2007/12/26 3:45
kelley RE:Need some 30lb/hr injectors
thomasville ga
122 Posts
their a couple on ebay,,
Posted on: 2007/12/26 15:31
CSS996 RE:Need some 30lb/hr injectors
Mega Guru
Central PA
3644 Posts
I could check around locally. But I don't have that kinda cash lying around anymore. If you can Paypal me the funds, then I could buy them and ship them to you. Hopefully you have a better option, but I am here to help if I can.
Cheers.
Posted on: 2007/12/26 16:08
Currently "Between Vettes".
Notorious RE:Need some 30lb/hr injectors
The 30# FMS injectors are what I use now. I've got some low-mileage LS6 injectors that are 28#. But they require a pressure boost (to C5/LSx pressure levels) to be fully utilized to that rating. Not a problem if you have an AFPR.
Posted on: 2007/12/28 0:50
I hate sporks...
CasetheCorvetteman RE:Need some 30lb/hr injectors
Thanks blokes
What is the pressure used on the later injectors? I dont have an AFPR, and id prefer to stick with the regular one if i can.
Posted on: 2007/12/28 6:35
RRTvette RE:Need some 30lb/hr injectors
Bogalusa, LA
50 Posts
Hey Casey, long time no see. Sorry I can't help with locating the injectors as I don't have that size lying around or know anyone here locally with a set. However you can probably get the tune just right without having to purchase a AFPR.
Posted on: 2007/12/28 6:41
Be good if it was that simple, but not with 28lb/hr injectors requiring a higher pressure i wont, the stock units in there now are reaching 100% duty cycle before the redline. They simply cant let enough fuel through anymore.
Posted on: 2007/12/28 6:58
biggrizzly RE:Need some 30lb/hr injectors
I just saw to sets of used ones on eBay. One was $185 US and $9 shipping CONUS no information for OCONUS shipping
The other set was around $195 or $200, no information on shipping
Posted on: 2007/12/28 16:29
SpectatorRacing RE:Need some 30lb/hr injectors
Thanks blokes
I also use the FMS 30#.
Not sure if this is what you're asking, but the standard FP for a Ford is ~38 psi, so our 43 psi is a bit more.
Posted on: 2007/12/29 21:14
Yep, i know that bit, which is perfect i reckon, but i was wondering about the pressure used on the later model Corvettes where these LS6 injectors came from.
Im leaning towards the FMS 30lb/hr though, seems like a very good option to me.
Posted on: 2007/12/30 2:11
Gotcha. Can't help you there.
If you do, check them before you install. They work great, but often come from the factory sticking. 2 of mine were sticking and it took me forever to figure it out - new parts can't be bad out of the box, can they?!? Four or five people on the other forum had the same issue.
Just run 'em through an injector cycler or bang them on the workbench a few times to make sure...once they're free they work forever.
Posted on: 2007/12/30 2:59
No worries mate, thanks for that little tip there
Posted on: 2007/12/30 3:06
