295 user(s) are online (238 user(s) are browsing Forums)
Danspeed1 Installing AVIC-F900BT In C6... Where do the "noise filters" go?
Mooresville, North Carolina
1121 Posts
Hello,
I am installing a Pioneer AVIC-F900BT in the C6. I was reading and it seems as though I need to add one of these...... http://www.parts-express.com/pe/showdetl.cfm?Partnumber=265-042 .... and a couple of these....... http://www.parts-express.com/pe/showdetl.cfm?Partnumber=265-012 ... except, I have absolutely no idea where they go and what they do.... anybody car to explain.
Thanks,
Dan
Posted on: 2009/5/9 3:16
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
Matatk Re: Installing AVIC-F900BT In C6... Where do the "noise filters" go?
They are for eliminating alternator noise/ignition interference if you have an amp and subs. On some systems you can turn the radio all the way down and hear a hum coming from the subwoofers or speakers that will increase/dercrease while revving the engine. They are not necessary in a properly installed system with good grounds. I do not believe you need one.
Edit - ps, the second one is for home stereos.
Posted on: 2009/5/9 11:39
Durango_Boy Re: Installing AVIC-F900BT In C6... Where do the "noise filters" go?
Yeah those are simply Band-Aids for a problem that can be solved with proper wiring and grounding.
Posted on: 2009/5/9 12:49
Danspeed1 Re: Installing AVIC-F900BT In C6... Where do the "noise filters" go?
1121 Posts
Oh, Cool,
I was miss informed I guess... thanks for clarifying guys!
DG
Posted on: 2009/5/10 2:44
1996 Ford Explorer
2009 Cadillac CTS-v
