WW7 | Is hatch glass adjustable?? | ||
Is the rear glass on my 89 adjustable? The glass is sitting to close to the back edge on the drivers side and I need to adjust it up towards the top or front, more. If it does adjust , how???.Thanks...WW
Posted on: 2009/5/11 16:42
Matatk | Re: Is hatch glass adjustable?? | ||
I've seen this question come up before and never saw a good answer on it. I checked the FSM for my 89 and unfortunately there is no real reference in there to adjusting the back glass.
The glass itself should be glued onto the hinge and then the hinge attaches to the halo area with three or four nuts. I believe there is a minor adjustment that can be made to this mounting point. I also believe you have to remove the interior halo panels to get to this. Good luck and be careful with the glass. It is no longer produced by GM or it's suppliers and a used hatch glass will run you $250-$400. Post up your results if you find something. Matthew |
Posted on: 2009/5/12 1:30
OK, I did a little more digging and found a very interesting article on the ZR1netregistry.com:
http://www.zr1netregistry.com/ZR1_hatch.htm Quote: ZR-1 Hatch Shifting Hope this helps! Matthew |
Posted on: 2009/5/12 1:35
