177 user(s) are online (117 user(s) are browsing Forums)
Assembly Line Diagnostic Link
Corvette90 396 oil pump issue
11 Posts
hi all
as some of you know, theres just a topic going on in another forum, oil pump desaster....
i also have a "sealed power" SV, SP pump in my 396, and this oil pump breakage nightmare give me some headache...
i want to install a 10552, or a 10555 pump, ( i have the 10555 at home), which one would you recommend me?
10%, or 25% more volume? any downsides? i run a canton road race pan....
thanks for input
Posted on: 2007/12/31 13:23
bogus RE:396 oil pump issue
if it was me, I would run the stock pump. The volume is enough and so is the pressure. The OEM pumps are good for 200k or more miles, too. Great design, really.
Posted on: 2007/12/31 19:03
CFI-EFI Re: 396 oil pump issue
Top of Utah
372 Posts
Have you run this engine at the track? Do you feel the stock pump isn't doing the job? The labels, "high volume" and "high pressure" don't necessarily mean what you might first think they mean. Unless you know the stock pump won't do the job, and you understand the oiling system and what the pump "labels" mean, you are best off sticking with the stocker.
RACE ON!!!
Posted on: 2007/12/31 19:30
85vet RE:396 oil pump issue
Pittsburgh, PA
16 Posts
The 10552 is the equivalent of the stock High Performace Camaro pump and if you have a larger pan you will be fine. I like just a little xtra oil for safety sake. It is not required, but for me peace of mind.
Posted on: 2007/12/31 19:51
85-Z51 4+3 - Now 700r4
427, TPIS Solid Roller700/701-ported AFR 220, Rossler700r4, 4,000 stall (Engine by CORKVETTE1), 3.54 gears
Corvette90 RE:396 oil pump issue
11 Posts
Hi
the pump is a sealed power SV, SP pump...
what gives me headache is, that this pump is the weak casting, which give a good possibility of failure, especially used in stroker motors...
i run a Canton road race pan 240-15T IIRC
thank you
Posted on: 2008/1/1 2:07
Pittsburgh, PA
16 Posts
Pull your current pump & replace it with the M-select of your choice.
Do it NOW!!!!!!!!!!!
Posted on: 2008/1/1 4:23
11 Posts
i hear you!!
and i will do so, for sure (10552, or 10554)
thank you for your advice!!
Posted on: 2008/1/1 11:56
Corvette90 maybe worth a look
11 Posts
d***
just searched google for this pump issues....and come up with a related, but different story (hopefully no dupe)
what material are the pump gears made of?
it seems, that Melling uses powdered metal, that tends to crack and locks the pump....and not only Melling, also other manufacturers...
http://www.4m.net/archive/index.php?t-9657.html
http://speedtalk.com/forum/viewtopic...44a8b3c875d287
http://speedtalk.com/forum/viewtopic...69f83120f28c85
its slowly getting a pump nightmare...
Posted on: 2008/1/2 21:56
