Flashman | Need Help mounting clutch pedal in 86 vette | ||
Hi All,
I am in the process of converting my 86 auto vette to a manual transmission. I am trying to mount the clutch pedal but I am having problems getting it to mate to the aluminum crossbeam and the firewall. The top of the bracket is angled. The holes are drilled for the master clutch cylinder. Does the clutch pedal mount on top of the crossbeam? Also, looking at the pedals, is the clutch higher than the brake pedal? I am having a hard time trying to mount that clutch under the dash. I did have a lot of fun mounting the brake pedal. I had to use my auto mounting bracket because the holes were in different locations mounting to that wonderful crossbeam. Any info or pictures will be appreciated as I will continue to work on this car all week. Thanks. Joe |
Posted on: 2009/7/7 4:11
jhammons01 | Re: Need Help mounting clutch pedal in 86 vette | ||
damn, you bit off a lot in one bite.....
I feel for ya mang. |
Posted on: 2009/7/7 5:48
Flashman | Re: Need Help mounting clutch pedal in 86 vette | ||
Hi,
Yeah thanks. But when I start a job like this, I see it thru. I will work on it everyday until it is finished. Working under the dash of a corvette is a back breaking job. My hands and arms are all bruised and cut up from just doing the clutch pedals. Yanking the trans, exhaust and drive shaft was a piece of cake. Stressed but not going to give up. All I need is a picture of a 84-88 corvette clutch pedal mounted to the crossbeam underneath the dash. I will be back to work on this when I finish my deliveries today. Take care. Joe Flash |
Posted on: 2009/7/7 13:32
Lemme see if I feel industrious enough to crawl under there later today.
I didn't put any lube on my Clutch MC when I swapped it out early last Spring. It creaks now....my 7 year old told me that I couldn't race that car....I asked her why??.....she just pointed at the foot area and the next time I pushed the clutch, she said "There....because of that" meaning the creak noise. So I have to get under there anyway... |
Posted on: 2009/7/7 16:10
CentralCoaster | Re: Need Help mounting clutch pedal in 86 vette | ||
I was tempted to get a pic but it required pulling the plastic kick panel which is kinda tedious.
Do these diagrams help any? |
Posted on: 2009/7/7 17:05
Hi Guys,
Yes, the diagrams do help. I am mounting it the same way it says in the diagram. It also looks like the same bracket from the 84. Well I am just gonna get it mounted to the firewall and where ever that angled top bracket ends up, I will make a spacer or fabricate some way to mount it. I know its a pain to remove that plastic cover to gain access to the clutch & brake pedals. I have asked all my Corvette friends and nobody knows. I wish I had some local friends with a 84-89 4+3 car. There is one for sale a few miles away. I should pretend I am interested in buying it. But I think the owner would get pissed if I started ripping his car apart. Lol. Thanks for the info. I will snap some photos as I am trying to mount it. Talk later. Joe Flash |
Posted on: 2009/7/7 18:02
Hi Guys,
Im done. The bracket will not line up or flush to the firewall without hitting the cross beam. I cant even manauver the bracket to line up the bolt holes for the master clutch cylinder. I posted pictures of the clutch on the master clutch cylinder thread. The only way I can mount it is if I cut the front left side of the bracket and fabricate it. I say again, either I have the wrong clutch mounting bracket for an 86 or the aluminum cross beam is different on a automatic corvette than a manual 4+3 corvette. There is no part number stamped on the clutch mounting bracket so that even makes things harder. I will do more searching before I cut the bracket. Joe Flash |
Posted on: 2009/7/7 19:42
Hi Guys,
Figured it out. The used corvette parts place sent me the wrong pedals. They are for a 90 and up corvette. The clutch assemblies look very similar. The brake is definately wrong. You know, I depend on Corvette parts suppliers to know what they are doing and this is what happens. Well, I am sorry to trouble you guys with this problem. Joe Flash |
Posted on: 2009/7/7 23:22
