JonnyAngle | Am I knocking? | ||
I've got an early '86...
When I let the vehicle idle, whether at a stop light or in the garage, after a good 30-45 seconds I get this noise. It sounds as though the rocker arms are making this noise. The noise only comes from the drivers side. It sounds about the same frequency as a machine gun doing blasts. Is my engine knocking? The rpms dip about 1000 rpms when the noise happens and it sounds like the engine is bogging. Thanks, Jack |
Posted on: 2009/7/9 1:34
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. |
BeachBum | Re: Am I knocking? | ||
Whats your oil pressure when idling after 30 seconds ?
Posted on: 2009/7/9 1:51
JonnyAngle | Re: Am I knocking? | ||
between 32 and 40 psi
Posted on: 2009/7/9 16:59
