213 user(s) are online (148 user(s) are browsing Forums)
JonnyAngle Am I knocking?
Minneapolis, MN
151 Posts
I've got an early '86...
When I let the vehicle idle, whether at a stop light or in the garage, after a good 30-45 seconds I get this noise. It sounds as though the rocker arms are making this noise. The noise only comes from the drivers side. It sounds about the same frequency as a machine gun doing blasts. Is my engine knocking? The rpms dip about 1000 rpms when the noise happens and it sounds like the engine is bogging.
Thanks,
Jack
Posted on: 2009/7/9 1:34
BeachBum Re: Am I knocking?
751 Posts
Whats your oil pressure when idling after 30 seconds ?
Posted on: 2009/7/9 1:51
JonnyAngle Re: Am I knocking?
Minneapolis, MN
151 Posts
between 32 and 40 psi
Posted on: 2009/7/9 16:59
