281 user(s) are online (230 user(s) are browsing Forums)
CFI-EFI A Different Cleaning Problem
Top of Utah
372 Posts
Here is a question I haven't seen addressed before. I wrote a huge post detailing all the circumstances, but long story short. How can I clean a TBI fuel injector, where RTV has been used in the fuel system? After a few weeks with no apparent problems, suddenly it no longer sprays at all. Is there help for this?
RACE ON!!!
Posted on: 2009/7/6 19:20
Matatk Re: A Different Cleaning Problem
Do you want to clean them yourself or send them out and have them ultrasonically cleaned? I know FIC does cleaning/rebuilding for a very reasonable price.
Posted on: 2009/7/7 14:24
CFI-EFI Re: A Different Cleaning Problem
Top of Utah
372 Posts
Maybe I misunderstood. I thought this section was a vendor site for FIC. I am aware FIC cleans, services, and rebuilds fuel injectors. That is why I posted here. I was seeking professional advice on this particular situation. If I was predisposed to sending it out, I would have already done that. Should I have sent FIC an e-mail? Thanks.
RACE ON!!!
Posted on: 2009/7/7 23:41
FICINJECTORS Re: A Different Cleaning Problem
Gold Sponsor Vendor
117 Posts
RACE ON!!!
the TBI injector on the crossfire can take a lot of abuse.. Until the coil goes. We get a number of these in a month caked with all kinds of stuff. They all work fine after the service. But, if the coil is gone we replace the injector. I have not found an aftermarket injector that I like as a replacement. The OEM front and rear have a half cone pattern that the aftermarkets don't have. This IMO hinders the performance. We usually have these in stock as exchange units but the cores are getting hard to find in good shape. Soon we will have new coil assembly's to replace the bad coils. I am just waiting for a good tool to open the case..
Jon
Posted on: 2009/7/8 4:23
Top of Utah
372 Posts
Jon
Thanks for the reply. What I quoted is where you lost me. I have not noticed a different spray pattern between my front and my rear injectors. Have I not looked closely enough? I never noticed a "half cone pattern". Also, it isn't clear to me, which you are saying "This IMO hinders the performance.", the OEM or the after market injectors. Is the silicone a unique situation? Is this something I can deal with at home, on my own? Would it help if I posted or e-mailed the long detailed description of the circumstances? Thanks.
RACE ON!!!
Posted on: 2009/7/8 19:00
Gold Sponsor Vendor
117 Posts
CFI-EFI wrote:
Jon
RACE ON!!!
i don't know if you have ever seen the video we did on the tpi service but here it is. Maybe it will answer your question.. However the front and rear injector have different part numbers, the pattern if viewed from the side are distinctly different. The silicone you talked about can only enter the injector through the filters. There is a port on the side (about 1/8 diameter and on the bottom is the main intake. Both filters are 10 micron.. i do not believe a droplet of silicone can penetrate the filter, but it could coat it. As far as the aftermarket injectors., again its my opinion that they are inferior to the OEM. At the time, TBI was something that RP products really spent a lot of time and money working out. TPI was more efficient so they changed gears but continued the use in other lines. RP did not develop an injector till 89 for the TPI (the multec) Bosch and Lucas were used from 85 -88, You can e mail me other concerns or details to info@fuelinjectorconnection.com
thanks
jon
here is the link to the video
http://www.youtube.com/watch?v=HUbsOYPoQcw
Posted on: 2009/7/8 23:05
Top of Utah
372 Posts
thanks
jon
Jon,
Thank you. I have long been aware that the front and rear TBs used different injectors. The only difference I have heard of was in the flow ratings. I have never heard before of a different spray pattern nor have I ever noticed one. Certainly, I will look closer. With the swirl plates beneath the TBs and the plenum of the manifold as it is, I can't imagine the purpose. You are the expert. I appreciate the info.
Your information and speculation concerning silicone getting into the injector is encouraging. I will take you up on your offer, and I will e-mail all the details surrounding my problem. Thank you.
RACE ON!!!
Posted on: 2009/7/9 18:13
