311 user(s) are online (250 user(s) are browsing Forums)
Durango_Boy Smallest Transfer Case?
What's the smallest transfer case that will bolt to a SBC? Lightweight and small and keys.
Posted on: 2009/6/16 1:19
BrianCunningham Re: Smallest Transfer Case?
Transfer case?
Thinking of making an AWD Corvette?
BTW there's a C3 with AWD and a turbo LT1
Posted on: 2009/6/16 13:48
rklessdriver Re: Smallest Transfer Case?
2spd or hi-range only???
In the 1980's 4WD Nissian trucks had a very small divorced transfer case that is very popular with light class Mud boggers. Its also fairly strong.
The 4WD S-10 transfer cases will bolt up to a Th350 or 7004R/4l60 but even thou its a gear drive it is not very strong. Very popular with light class mud boggers as well that don't want the hassel of fabbing up drive shafts for a divorced transfer set up.
On the hi-range only spectrum. The Olds Bravado had a full time hi-range transfer and it is the same on used in the GMC Syclone and Typhoon but much easier (and cheaper) to find in a junk yard.
If you want small, lightweight and indestructable there are these.
http://www.scsgearbox.com/default2.asp?active_page_id=142
Posted on: 2009/7/14 19:23
Durango_Boy Re: Smallest Transfer Case?
Actually this was for a different project I was digging into with a friend. I like the Old's Bravada setup. Might research that a little bit.
Posted on: 2009/7/14 21:54
