219 user(s) are online (88 user(s) are browsing Forums)
Does it work?
Sweet90 Newest Hack And It's Been Done....... Scary......
Edmonton, Alberta
1143 Posts
Power-Line Exploit” Logs Your Keystrokes Using Outlets
Thinking about plugging your laptop into one of those coveted aeroplane terminal power outlets while you wait for your flight to arrive? Be careful, because a hacker could be using those energy-giving wires against you.
The technique is a form of keylogging, which is nothing new, but in an interesting twist hackers have figured out a non-traditional way to replicate the process using nothing but the electric signals created with each keystroke. Oh, and even if you aren’t plugged into a socket, they they can still log keystrokes remotely using a laser.
Called the “power-line exploit,” the two-part technique is outlined in a Network World article ominously headlined “How to use electrical outlets and cheap lasers to steal data,” and will be but one of several nefarious data-stealing methods on display at Black Hat USA 2009 in Las Vegas later this month.
Network World explains:
In the power-line exploit, the attacker grabs the keyboard signals that are generated by hitting keys. Because the data wire within the keyboard cable is unshielded, the signals leak into the ground wire in the cable, and from there into the ground wire of the electrical system feeding the computer. Bit streams generated by the keyboards that indicate what keys have been struck create voltage fluctuations in the grounds.
[If the laptop is unplugged], attackers point a cheap laser, slightly better than what is used in laser pointers, at a shiny part of a laptop or even an object on the table with the laptop. A receiver is aligned to capture the reflected light beam and the modulations that are caused by the vibrations resulting from striking the keys.
Posted on: 2009/7/15 21:00
pianoguy Re: Newest Hack And It's Been Done....... Scary......
Delightful!! May hackers everywhere be plagued with painful rectal itch.
Posted on: 2009/7/15 21:16
Sweet90 Re: Newest Hack And It's Been Done....... Scary......
Edmonton, Alberta
1143 Posts
I agree and that would just for starters
Jim
Posted on: 2009/7/15 21:17
CSS996 Re: Newest Hack And It's Been Done....... Scary......
Mega Guru
Central PA
3644 Posts
So can you simply shield the data wire to solve the problem?
Somebody get my small screwdrivers and the aluminum foil!
And a 9 iron...
Posted on: 2009/7/15 22:04
Currently "Between Vettes".
Durango_Boy Re: Newest Hack And It's Been Done....... Scary......
They can key log me all they want, all they'll catch me doing in an airport is playing Majjong.
Posted on: 2009/7/15 22:50
vetteblondie Re: Newest Hack And It's Been Done....... Scary......
Jonesboro, AR
4681 Posts
porn surfers?
Posted on: 2009/7/16 1:49
�Ugol's Law
