klkordzi | Harmonic Balancer Question | ||
I'm putting the engine back together on my 85 and found it interesting that there wasn't a timing tab on the engine. Aside from that, when I have the engine at top dead center on the compression stroke. the mark on the balancer is not at the 0 mark on the tab (2 o'clock), it's at 10 o'clock. Is this right? Also was the timing tab left off or didn't it come with one?
Posted on: 2009/8/8 16:29
bogus | Re: Harmonic Balancer Question | ||
ouch. I am not sure what to suggest here...
Posted on: 2009/8/8 22:21
rklessdriver | Re: Harmonic Balancer Question | ||
Sounds like most likely the Harmonic Balancer's outer ring has slipped on the hub.
Most SBC's TDC mark are at 2 o'clock althou some are straight up at 12 o'clock, so you have to be careful that you have the correct timming cover/tab/harmonic balancer combination. Will |
Posted on: 2009/8/8 22:30
klkordzi | Re: Harmonic Balancer Question | ||
I changed the timing cover when I changed the cam and added an aftermarket timing tab. I was thinking that the balancer had slipped since the timing mark was so far out but when I looked at the elastomer it didn't look like it had slipped. So pretty much the timing mark will line up with the keyway on the crank right?
Posted on: 2009/8/8 22:46
vetteoz | Re: Harmonic Balancer Question | ||
klkordzi wrote: added an aftermarket timing tab. Was the timing tab correct for your engine.The position changed over the years |
Posted on: 2009/8/9 0:18
anesthes | Re: Harmonic Balancer Question | ||
Older ones were more in the 12 oclock position, then they moved to like 2 oclock. Best to get a new balancer and timing tab.
Posted on: 2009/8/9 3:40
'79 Z28. 412 CID, NP 833 transmission, 3.73 10.5" rear end. |
