j3studio | [!@#$% 1985 Digital Cluster] Need Context And Advice | ||
The digital cluster in my 1985 has worked great for almost five years. I drove the car today and one of the elements on the speedometer began to flicker, recovered for a couple of minutes, flickered again, and went out. Cycling power did not change the behavior.
If all elements are lit, the one missing looks like this: .. _ .. _ | |_| ._| | |_| |_| (please excuse the white periods - the interpreter doesn't like multiple spaces) What's the likely diagnosis? To me, it seems like the element itself or its connection has gone bad, because the rest of them are still reading a speed that matches the bar graph speedometer. Two more questions: 1) Is this something I can fix myself? 2) If I can't fix it, who would you suggest to do the work? Of course, I need this to work by mid-September, when I'm attempting a performance verification. |
Posted on: 2009/8/22 19:58
bogus | Re: [!@#$% 1985 Digital Cluster] Need Context And Advice | ||
I would remove the IP and ship it off to one of the rebuilders. Just have the entire thing gone through and be done with it.
Yes, it will cost a ton... but it will be done and done right. You won't have to worry for a long while. Losing an element like that isn't good... it means the LCD is failing on that part. |
Posted on: 2009/8/22 21:03
Matatk | Re: [!@#$% 1985 Digital Cluster] Need Context And Advice | ||
Flickering is usually a bad ground. If you are missing a line, from what I understand that is a dirty contact. Check batee.com for the best info on that.
Matthew |
Posted on: 2009/8/22 21:04
j3studio | Re: [!@#$% 1985 Digital Cluster] Need Context And Advice | ||
Can't believe Andy is telling me to punt...
Posted on: 2009/8/22 22:49
Yea, I am... its one component of a C4 I won't touch.
Since you want to keep the car perfect, you can waste a lot of time jerking around with patches and fixes... just unass the cash once and be done with it. |
Posted on: 2009/8/22 23:00
It makes me feel better that you are endorsing the direction I was probably heading in - this is especially painful because the rest of the car is working so well. |
Posted on: 2009/8/22 23:42
CentralCoaster | Re: [!@#$% 1985 Digital Cluster] Need Context And Advice | ||
Whoa..... slow down, this is doable.
You will need to open up the cluster and remove the rear circuit board to get to the LCD panes. The rear board is tricky as it's held in by a row of pins to the front board which can be very difficult to pull lose. Unscrew it and then try wriggling that rear board loose from those pins... When you get that board off, the front board comes off next. Now, there's some pink/orangish rubbery strips in there that are surrounded with plastic retainers, these make contact with the LCD panes which are simply clamped against them when the front board is screwed in. I would try removing the pane in question and gently clean the edges where these strips contacts it. It may be stuck to the pane, but don't worry, it's not glued on or anything, and if you carefully loosen it it won't hurt anything. If you actually touch the contact points on the strips, you'll notice parts of the lcd panes light up! Ok, probably not a good idea to screw with that too much. Anyhow, upon assembly, double and triple check that you get the panels in correctly, it's tricky to get them seated flush and get all the rubber spacers in properly. |
Posted on: 2009/8/23 5:58
rayquayle | Re: [!@#$% 1985 Digital Cluster] Need Context And Advice | ||
:me2: Especially the last paragraph. Don't want to crack an LCD! If you get stuck, I've got a couple that I've rebuilt on the shelf. I can send you one to use for your verification and until you get yours working. |
Posted on: 2009/8/23 8:18
Ray Quayle in England '86 Indy PaceCar, 4+3 NCM Founder #2896 NCM Lifetime #672 Graduate of Gordon's School |
CC, you are giving my remaining skills too much credit (I last did real electronics repair 20 years ago). It damned near killed me just to get the damn thing out of the dash - though at least it didn't scar me like my C5's EBCM did a couple of month's ago. If I had more time, I might mess around; but I don't. It's shipping out tomorrow morning. |
Posted on: 2009/8/23 20:58
