122 user(s) are online (64 user(s) are browsing Forums)
1st Gear: 2.48
2nd Gear: 1.48
- 13 Bolt ...
jonecap ASR/Traction Control unit delete - how to? I fried it : (
33 Posts
Long story, but I managed to fry my ASR/traction control unit today. It had something to do with me bolting the bracket down on top of the hot wire for my electric water pump. Not cool, especially considering I can't drive the car now.
Now I'd like to figure out how to get rid of the traction control unit altogether. I think it would look cleaner under the hood without it and I don't need it. Unfortunately, the cruise control and throttle cable are tied into the unit. I'm sure someone else has done this. Would it work if I got a throttle linkage assembly off of a pre-traction control car?
Anybody done this already?
Thanks guys!
Posted on: 2009/8/24 0:22
'02 Z06 - 11.58 @ 117.40 CAI & ET Streets only...
Sold but not forgotten:
'96 CE LT4
11.65 @ 118.76 LT4 hotcam, gears, tires, and exhaust
10.72 @ 128.90 on the jug ;)
'90 Z51 6 speed- 13.10 @ 105.07 with lots of...
bogus Re: ASR/Traction Control unit delete - how to? I fried it : (
Call www.vette2vette.com and get a new ASR module.
Posted on: 2009/8/24 3:16
EricVonHa Re: ASR/Traction Control unit delete - how to? I fried it : (
30 Posts
Does the car run now from the unit being fried?
To me, the issue is purely mechanical. You should be able to disconnect the electrics and it should run fine.
** your throttle cable does work fine when the car is off & I can't comprehend that GM didn't make it a failsafe system.
Posted on: 2009/8/25 23:18
jonecap Re: ASR/Traction Control unit delete - how to? I fried it : (
33 Posts
No, it doesn't work that way. It is not a direct linkage between the pedal and the throttle for some reason. The ASR unit controls the linkage. Right now I can physically press the gas pedal in the car even though it is stiff, but the throttle does not open. I took the cover off the unit and it is not a direct connection. The car will start fine, just no throttle.
Posted on: 2009/8/27 0:42
'96 CE LT4
There is a motor and a clutch inside that piece. I am shocked that it isn't working without the motor working.
Posted on: 2009/8/27 6:43
SpectatorRacing Re: ASR/Traction Control unit delete - how to? I fried it : (
I ran a new throttle cable directly to the throttle body.
Posted on: 2009/8/27 15:57
33 Posts
Got it fixed. Found a new traction control module on eBay for $25, plugged it up and I'm good to go. Gotta love cheap C4 parts!
Posted on: 2009/8/30 13:07
'96 CE LT4
