jonecap | ASR/Traction Control unit delete - how to? I fried it : ( | ||
Long story, but I managed to fry my ASR/traction control unit today. It had something to do with me bolting the bracket down on top of the hot wire for my electric water pump. Not cool, especially considering I can't drive the car now.
Now I'd like to figure out how to get rid of the traction control unit altogether. I think it would look cleaner under the hood without it and I don't need it. Unfortunately, the cruise control and throttle cable are tied into the unit. I'm sure someone else has done this. Would it work if I got a throttle linkage assembly off of a pre-traction control car? Anybody done this already? Thanks guys! |
Posted on: 2009/8/24 0:22
'02 Z06 - 11.58 @ 117.40 CAI & ET Streets only... Sold but not forgotten: '96 CE LT4 11.65 @ 118.76 LT4 hotcam, gears, tires, and exhaust 10.72 @ 128.90 on the jug ;) '90 Z51 6 speed- 13.10 @ 105.07 with lots of... |
bogus | Re: ASR/Traction Control unit delete - how to? I fried it : ( | ||
Call www.vette2vette.com and get a new ASR module.
Posted on: 2009/8/24 3:16
EricVonHa | Re: ASR/Traction Control unit delete - how to? I fried it : ( | ||
Does the car run now from the unit being fried?
To me, the issue is purely mechanical. You should be able to disconnect the electrics and it should run fine. ** your throttle cable does work fine when the car is off & I can't comprehend that GM didn't make it a failsafe system. |
Posted on: 2009/8/25 23:18
jonecap | Re: ASR/Traction Control unit delete - how to? I fried it : ( | ||
No, it doesn't work that way. It is not a direct linkage between the pedal and the throttle for some reason. The ASR unit controls the linkage. Right now I can physically press the gas pedal in the car even though it is stiff, but the throttle does not open. I took the cover off the unit and it is not a direct connection. The car will start fine, just no throttle. |
Posted on: 2009/8/27 0:42
There is a motor and a clutch inside that piece. I am shocked that it isn't working without the motor working.
Posted on: 2009/8/27 6:43
SpectatorRacing | Re: ASR/Traction Control unit delete - how to? I fried it : ( | ||
I ran a new throttle cable directly to the throttle body.
Posted on: 2009/8/27 15:57
aka Scaryfast |
Got it fixed. Found a new traction control module on eBay for $25, plugged it up and I'm good to go. Gotta love cheap C4 parts!
Posted on: 2009/8/30 13:07
