111 user(s) are online (75 user(s) are browsing Forums)
88BlackZ51 Issue bolting up Holley TB to Miniram!
481 Posts
Another issue:
As you can see in the pictures, I am having another issue in regards to bolting on the 58MM Holley TB to the TPIS Miniram.
I took off the stock lower TB piece, and bolted it on the Holley unit(lower unit has the sensors/pipe). The issue now is that the pipe is rubbing up against the waterneck and I can't bolt up the TB.
For the record this is the TPIS waterneck, and not an aftermarket one.
Anyone else experience this issue? Any ideas what to do?
[IMG]http://i195.photobucket.com/albums/z275/88blackz-51/421swap019.jpg[/IMG]
[IMG]http://i195.photobucket.com/albums/z275/88blackz-51/421swap020.jpg[/IMG]
Posted on: 2009/8/26 0:56
88BlackZ51 Re: Issue bolting up Holley TB to Miniram!
481 Posts
I am a dumbass. I have to cut it off. I got all excited for nothing!
Posted on: 2009/8/26 1:09
BrianCunningham Re: Issue bolting up Holley TB to Miniram!
ready
fire
aim!
j/k glad you found the problem
Posted on: 2009/8/26 1:13
481 Posts
it wont be the last issue...
Posted on: 2009/8/26 1:23
Matatk Re: Issue bolting up Holley TB to Miniram!
22812 Posts
Are you referring to the coolant passage for cold starts (ie, throttle body bypass nipple)? If so, glad you found your issue.
PS, I deleted the other duplicate thread.
Posted on: 2009/8/26 2:12
